Results 161 to 170 of 251
Thread: Avanza Engine Problem
September 4th, 2011, 02:29 PM #161
- Aug 2011
- 3
Re: Avanza Engine Problem
Boss, bagong bili lang Avanza ko 1.5G (kakabili lang Sept 1 - pero saw in the stickers na May 2011 pa nadeliver sa casa), medyo napapansin ko rin yan, parang akyat baba ung RPM kahit naka park lang ako with engine and aircon on, not sure kung this is normal though. Feeling ko kasi one reason ito kung bat di ko feel ung tipid sa FC.
September 5th, 2011, 06:40 PM #162
naitanong ko rin to nong bago palang vanzy ko sir....normal lang daw yan. pag naka aircon tapos park ka taas baba from 800-1k rpm nyan....dahil sa aircon yan.
visit this website too sir...avanza forum yan.
http://www.avanzaclub.ph/forum/
September 7th, 2011, 12:09 PM #163
- Aug 2010
- 48
Guys pa help naman po, whenever I step my foot on brake may naririnig akong parang lumalagatok sa harapan. Kinakabahan tuloy akong i byahe ng malayo ang zoomy ko. Sinabi ko na to sa SA ko nung nagpa 15K PMS ako, nawala naman ung tunog pero after ilang weeks bumalik ulit. Avanza G 1.5 ung sakin 2010 model nasa 19K na ang odo. Any information is greatly appreciated. Thanks.
September 7th, 2011, 12:49 PM #164
Yup normal lang yan, it's the alternator compensating for the electricity needed. Maliit kasi battery ng avanza kaya mas mabilis na ma-drain. Lagyan o yan ng 3SM na MF pa, tagal yang akyat baba niyan. Kaso addt'l cost pa tapos fabrication aksi malaki. hehe
September 7th, 2011, 02:14 PM #165
September 7th, 2011, 03:49 PM #166
- Aug 2010
- 48
September 10th, 2011, 08:45 PM #167
may "tug" sounds din sa akin kung minsan,
ang tunog ay galing sa propeller "play"
September 11th, 2011, 10:10 AM #168
September 12th, 2011, 09:52 AM #169
- Aug 2010
- 48
October 9th, 2011, 08:38 PM #170
Hello fellow ACPers!
Need your input. I've been experiencing engine vibration this past few weeks with my avanza usually during startup after several hours of being idle. Dati, pag start, nasa a little over 1,000 rpm siya then slowly bumababa.
Lately, sa startup pa lang, medyo mababa na siya at around 750 rpm, then mag lolower pa siya tas biglang mag vivibrate na. Though several times na nangyayari yan, minsan pa lang naman ako namatayan ng engine and thank God habang naka park pa naman. All of these times off ang aircon and lights.
Diba usually may tumutunog na parang "pitik" or switch na naririnig tapos tataas ang rpm? Diba yan yung thermostat (which activates the fan)? Pag bumababa siya sa 750 rpm, after a short while, pipitik siya then tataas ang rpm pero bigla naman ding bumababa. Talagang unusual ito kasi hindi ito nangyayari dati.
Just last night, bago ako umalis ng bahay, nangyari na yung vibration. Pero pinatakbo ko pa rin. There were times on the road na kahit apakan ko ng full ang gas, wala siyang hatak at di man lang umangat ang rpm. Parang naka neutral akong tumatakbo. Tapos biglang kakagat uli. :o Buti na lang at wala akong kasunod kasi pag andar ko pag green ng traffic light, parang primera lang ang takbo ko at ang rpm ko is about 1000-1250. Natakot tuloy ako at baka biglang tumirik.
For me, top of mind kaagad pag low rpm while stationary is too low idling. Could that be the case?
Ilang araw na rin ang sunud-sunod na pag-ulan dito. Could it be caused by a cold engine? (Temp Gauge indicates otherwise)
Gusto kong dalhin na sa casa kaya lang it's a Sunday. Nagdadalawang isip tuloy akong lumakad with the family at baka biglang magka aberya.
My ride is a 1.5 G Matic acquired Dec 2010. Hope these info can help you tell me the probable causes.
Salamat ng marami!
you apply lang sa mga outlines at crevices ng emblem na may nanigas na dumi... ok na yan, make...
"Tamang OC lang" - a newbie's guide to car...
