Results 1 to 10 of 279
Thread: Avanza Engine Modification
July 7th, 2009, 10:31 PM #1
Mga bossing, meron na ba sa inyo nakagamit ng K&N drop-in air filter para sa Avanza? paki share naman ng K&N parts number kasi di ko mahanap sa K&N website yung specific for Avanza 1.5G. Baka meron kayong alam na compatible K&N drop-in air filter for Avanza. Dati kasi sa civic lxi ko gamit ko K&N drop-in air filter noticed ko talaga yung improvement sa fuel consumption and increase in power. I was able to shift into 5th gear pero RPM range nasa 1000-1250 lang and speed around 40-45kph pero walang engine shuddering. Kaya gusto ko rin lagyan ng K&N yung Avanza namin.
July 8th, 2009, 12:30 AM #2
Re: Avanza Engine Modification
Before, I tried looking for one (drop in replacement), kaso wala akong nakita. Thur last week, nagpalagay ako ng SRI.
July 8th, 2009, 06:03 AM #3
- Jun 2006
- 254
Bro
Wala available na K & N drop in filter para sa vanzy natin kaya chances are puro naka cold air intake ang setup. Kahit ako gusto ko k un drop in para stock air box
Jun
July 8th, 2009, 07:20 AM #4
ACP peeps,
try nyo -search kung may sasakyan na katulad ng air filter ng avanza.
If meron, visit the K&N site and get the part number ng katulad na sasakyan.
July 8th, 2009, 10:07 AM #5
Parang meron ako nabasa sa avanza club malaysia about it. hanapin ko ulit.
July 8th, 2009, 10:46 AM #6
Found it! Thank to our counterpart in Malaysia.
[SIZE=2]The K&N filter is one of a kind…a high-flow, washable filter that delivers the maximum amount of air possible into your engine while providing superior filtering. K&N filters are made of cotton gauze material (instead of paper) sandwiched between two layers of fine aluminum mesh which creates a grid-like effect, straightening and cleaning the air, resulting in dramatic airflow increases. This translates into improved power throughout the entire RPM range. Horsepower improvements vary, but a 5 to 10 horsepower increase is common. All this, plus you'll never have to buy another filter again! K&N filters can be cleaned over and over, and are backed by our million mile warranty!
[/SIZE]
- [SIZE=2]
- Maximum airflow without any restrictions compared to any other air filters available
- 100% dirt filtration
- Washable - serviceable
- One-time purchase - value for money
- Improve engine fuel economy and consumption[/SIZE]
[SIZE=2]
1. Turbulent air covers filter area.
2. Pleated multi-layered oil impregnated surgical cotton fabric.
3. Suspended dirt on the outside does not cause significant airflow restriction (to 50,000 street miles)
4. Oil barrier attracts and holds dirt to become additional filter medium without clogging filter.
5. Bonded cotton / wire mesh straighten airflow reducing turbulence.
6. Straightened and filtered high-volume air enters the intake system.
Those who wish to replace the original air filter of the Avanza to the K & N Drop-in Air Filter, the part number is 33-2041. This filter is actually for Kembara model(without DVVT).
Question : San nakakabili nito dito?
[/SIZE]
July 8th, 2009, 12:49 PM #7
mukhang tama nga yung part no. ni ngarcia...
July 8th, 2009, 12:59 PM #8
Boss Ngarcia, hindi kaya yung k&n part number is 33-2041-1? kasi walang lumalabas na 33-2041 lang, and yung 33-2041-1 di yata compatible sa avanza na vvti kasi yung dimension ng air filter natin is 9"x9"x1.25" (LxWxH) and dapat flat yung edging nya para makabit sa rubber seal yung filter element. the closest nakita ko na malapit sa dimension ng avanza air filter is 33-2076 pero mas malaki kunti and di flat yung edge, baka mahirap para sa rubber seal.
[SIZE=1]Product Number: 33-2076[/SIZE]
[SIZE=1]Product Style: Panel Air Filter k&n filters
Height: 1.25 in (32 mm)
Outside Length: 9.125 in (232 mm)
Outside Width: 9.188 in (233 mm)
Filter Re-Oiling Amount: 1.32 oz (39 ml)
Inner Wire: No
Top Style: Open
Weight: 1.1 lb (0.5 kg)
Product Box Length: 10.44 in (265 mm)
Product Box Width: 1.75 in (44 mm)
Product Box Height: 11.56 in (294 mm)[/SIZE]
[SIZE=1][/SIZE]
Meron akong nakita isang brand na parang K&N din and made in Indonesia and para talaga sa avanza 1.3 and 1.5 vvti pero sa Indonesia lang yata ito binebenta, baka pwede ito maging new line ni Boss Marfin yung brand is JFC Cotton Gauze Filter heto yung website http://www.jfcfilters.com/search1.php
July 8th, 2009, 05:02 PM #9
mga bossing heto product specs ng 33-2041-1
33-2041-1 Product Specifications Product Style: Panel Air Filter
Height: 0.938 in (24 mm)
Outside Length: 9.875 in (251 mm)
Outside Width: 6.188 in (157 mm)
Filter Re-Oiling Amount: 0.81 oz (24 ml)
Weight: 0.9 lb (0.4 kg)
Product Box Length: 7.72 in (196 mm)
Product Box Height: 13.56 in (345 mm)
I think hindi ito compatible sa Avanza vvti na filter box.
July 8th, 2009, 05:36 PM #10
Well looks like they're gonna make it easier na to transfer ownership. Timely since I need to...
transfer of ownership / registration cost
