Results 1 to 10 of 13
January 4th, 2009, 06:52 PM #1
Avanza DIY: Removing the Center Console
Para sa mga nagwo-worry na mahirap baklasin ang Center Console ng Avanza ito...
Step 1: Remove the Ash Tray from the console by opening it:
Step 2: And then pressing the ash tray lock downwards and pulling it out:
Step 3: Start the console removal by poking the center of this "pin" in:
Step 4: This is how it looks after poking in the center:
Step 5: You can use your fingernails to pull out the pin afterwards. Here's how it looks then:
To be continued...
January 4th, 2009, 06:58 PM #2
Re: Avanza DIY: Removing the Center Console
continuation:
Step 6: Next, remove this lever cover:
Step 7: Begin pulling out the console by pulling upwards. Hold it this way:
Step 8: That wasn't so hard now, was it? Now, pull out the top portion by pulling here:
Step 9: Top portion pulled out:
NOW you may do what you want with the stuff on the console... You may see some pictures of how the removed console looks like in my other DIY thread:
Avanza DIY - Defogger switch converted into Aircon Switch: http://tsikot.yehey.com/forums/showthread.php?t=51271
Of course, the next message will show how to put the console back in its place...
January 4th, 2009, 07:03 PM #3
Next, how to place back the console:
Step 10: Start by reversing the removal procedure -- from the top. Insert the top end, taking care not to break the locking clips at the top:
Step 11: Also take note of the side locking clips:
Step 12: And slowly bend the bottom portion towards you so that the lever will go into its proper slot, then push the bottom portion into its position:
Step 13: Push the left bottom portion into its place:
Step 14: Final push:
To be continued...
January 4th, 2009, 07:08 PM #4
Step 15: Take the locking pin and push out the lock out of the head up to this point. Be careful not to break the sides:
Step 16: Hold it by the center "nail" and insert it back into its position:
Step 17: Inserted position:
Step 18: Push the center in to lock it:
Step 19: Put back the ash tray. Note the side slots:
To be continued...
January 4th, 2009, 07:08 PM #5
Step 20: Slotted in, push down on the upper metal lock, and push the ash tray back into position:
Put back the cover of the aircon lever and all is done!
Hope this helps...
January 4th, 2009, 09:19 PM #6
nice one sir woh btw para san po ba pag tinangal ang center console ng avanza?
January 4th, 2009, 11:12 PM #7
January 4th, 2009, 11:46 PM #8
Thanks! Tagal ko nang hinihintay ito
January 4th, 2009, 11:52 PM #9
sabi na ganon lang eh.. hehehe.. thanks a lot for a very nice info chief!! hindi ko alam talaga kung pano tanggalin yung lock na maliit sa may ashtray..
January 6th, 2009, 09:18 AM #10
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
