Results 21 to 25 of 25
August 13th, 2008 12:00 PM #21
share ko lang about rustproofing and undercoating
Limitations of Undercoating and Spray-on Rustproofing
Undercoating and spray-on type rust proofing (rustproofing) insulates the metal from moisture and oxygen by covering it with a protective coating.There are two main disadvantages of this method.
- It's impossible to cover every area on the vehicle with this method and hard to reach places are left unprotected, often these are the areas that are most prone to corrosion.
- It's effective as long as the protective surface is not damaged. In real terms this is not possible and where damage occurs, no matter how small, rust will occur. Cracking at the body joints, stone chips, scratches, peeling and brittleness of the undercoating can result in water getting trapped between the metal and the undercoating allowing rust to form where you can't see it until it's too late. This is why many rust proofing and undercoating companies recommend that you get your car or truck inspected and re-sprayed every year. This, of course, costs you more money.
Even if your vehicle already has some type of undercoating it will probably still rust.http://www.ruststoponline.com/rustpr...tions.html#top
- Oct 2005
- 252
October 8th, 2008 02:22 AM #22ganito po ba talaga presyo ng pagpapa-undercoat? mukha kasing kailangang kailangan ng auto ko nito...
yung kotse ko po kasi palagay ko di pinapaundercoat ni erpats nung siya pa may gamit. last time na tinanong ko kasi siya sabi niya hindi. wala po kasi ako gaano alam about these things kaya madalas ginagawa ko nalang noon kapag nakikita ko yung wheel well, spary paint nalang na black, lalo na kapag kita ko yung paint ng kotse mismo... hanggang sa tinamad na ako.
parang naaawa tuloy ako sa new ride namin, kasi malamang it will suffer the same fate na di na ulit makakatikim ng undercoating...
October 19th, 2008 03:29 AM #23
Forbiddensmoke,
1 gallon = 2,200php
2 gallons = 3,000-3,200php (nakalimutan ko na presyo namin)Last edited by karlbo; October 19th, 2008 at 03:34 AM.
October 19th, 2008 12:37 PM #24
kelangan ko na din pa undercoat. sa mga gasoline station ba ok? meron dito sa amin malapit na ziebart, magkano kaya don?
thanks
- Jul 2005
- 298
October 19th, 2008 01:46 PM #25
Daming issue ng SU7:grin:
Xiaomi E-Car
