Page 772 of 784 FirstFirst ... 672722762768769770771772773774775776782 ... LastLast
Results 7,711 to 7,720 of 7833
    Jun 2011
    #7711
    Quote Originally Posted by ronki View Post
    Yup, kung totally dry yung surface ok lang.
    Kaso pag malakas ulan nababasa parin yung roof, then most likely nag si-sip in dun sa suction area kaya nag stick yung dumi.
    Baka wet sanding na need.
    Puwede try 3M swirl mark remover. Parang light duty rubbing compound. Apply kaunti sa damp na basahan.
    3M Car Care Swirl Mark Remover
    #7712
    Quote Originally Posted by bxr monkey View Post
    Gumamit na po ako ng MTX Supra 1.0 compound kaso gamit ko polishing pads sa DA.
    Baka need pa more aggressive product no...
    Jan 2008
    #7713
    parang nag stain na sya sa paint... try mo muna gumamit ng rubbing compound na nabibili sa paint shop.. yung amoy kerosene.. wag yung mga pang detailer na rubbing compound.. tapos apply mo lang by hand.. alalay lang
    Jun 2011
    #7714
    Same na pala sa 3M iyan. Try na i apply small concentrated amount (MTX Supra) sa damp cloth. Manual finger pressure rub, focus sa 1cm x 1cm area muna.
    #7715
    *monty_gtv, parang may konting galasgas na yung paint ng auto ko, accumulated dirt siguro. Once a month kasi iniiwan ko sa kalye para mainitan saka hindi na regular car wash ko. I forgot na, when I clay it, kailangan ko pa i KAIO? or clay > ksg > V07?
    Feb 2018
    #7716
    Ano kaya pwede pangtanggal sa wax na may humalo na ash (powerplant area kasi housing namin). natanggal ko naman majority, pero may mga naiwan padin na mantsa na hirap tanggalin. white pa naman kotse ko hahaha
    #7717
    basta sebo... it rhymes with bitoy...
    Feb 2018
    #7718
    huh thankss!
    #7719
    huh thankss!
    small area lng at first. if the beading goes away. baka iba na yun damage. good luck
    Jan 2008
    #7720
    use 3M 2000 grit sandpaper.. do wet sanding, then machine polish.. apply wax
"Tamang OC lang" - a newbie's guide to car appearance maintenance
