Results 7,701 to 7,710 of 7833
- May 2007
- 268
September 30th, 2020 01:42 PM #7701Mga sir, ano gamit nyo anti-rust spray na paint safe at rubber safe? May nakita ako konti rust sa door rubber seal banda.
Thanks in advance.
- 52,731
September 30th, 2020 02:02 PM #7702lift the weatherstrip (yung goma) up and you will probably see more rust. don't worry. that weatherstrip is designed for easy removal and installation.
use sandpaper or metal brush to remove what rust you can.
remove oils and grease, then apply the rust treatment.
after overnight, clean off and re-install the weatherstrip rubber.
some folks may want to paint the exposed metal surface to make it more appealing.
kung mamalasin,
upon cleaning off the rust, you might discover that there is considerably more rust there than you imagined.
good luck.
- May 2007
- 268
October 3rd, 2020 02:01 PM #7703
October 18th, 2020 04:29 PM #7704
I haven't detailed my car in a long time. After claying do I still need to KAIO and KSG? Can I just clay then straight Collinite 845 after then CG V07?
October 19th, 2020 02:32 PM #7705
Nagmamarka talaga yung suction cup nung car umbrella.
Minsan walang marka, minsan meron, ito yung mga matitibay.
Already tried clay, compound and polish kaso di nawala.
Used DA with Polishing pad tho. Takot pa sa cutting/wool pad hehe.
October 19th, 2020 07:24 PM #7706
October 20th, 2020 09:05 AM #7707
Yung ginawa ko sakin nung una is clay then collinite 845 na agad. Pansin ko madaling natangal yung wax (pero infairness, walang shade yung parking dito sa workplace so naaarawan at nauulanan sya). Tinry ko naman ngayon mag IPA (isopropyl alcohol) wipe after claying then collinite 845. Testing ko muna anong epekto sa durability.
Had no chance to try other products (like cleaner wax) kasi lockdown pa kami sa work.
Sent from my JEF-NX9 using Tapatalk
October 20th, 2020 09:08 AM #7708
October 20th, 2020 05:49 PM #7709
Yup, kung totally dry yung surface ok lang.
Kaso pag malakas ulan nababasa parin yung roof, then most likely nag si-sip in dun sa suction area kaya nag stick yung dumi.
Baka wet sanding na need.
October 20th, 2020 09:46 PM #7710
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
