Results 31 to 36 of 36
February 28th, 2008 01:32 PM #31
February 28th, 2008 10:59 PM #32
Eto ung gamit ko sa escape..
CIRCUIT Super Yellow: from Osaka, Japan
Output: 60/55W
Optical Equivalent: 100/90W
Low Beam Comparison
High Beam Comparison
New Front: Yellow foglamps looked like "whites" now..hehe
What I really like about these bulbs.. I got it for a cheap-price of Php120.00 per bulb.. Sana tumagal more than 3 months..hehehe Di ko na pinalitan sockets to ceramic and add ng relay.. next time na sa more powerful upgrade.
Just add "10pesos" for the real 100/90W output bulbs. Di ko alam talaga kung bakit mura.. pero pag mga instik may-ari ng auto parts store.. Sobrang mura talaga ng pricing nila.. Pag pinoy may-ari kailangan pa tumawad.
Narva all-weather bulbs.. ung may violet sa tip ng bulb cost around P300 per bulb.. kaso lagi nasisilaw mga kasalubong. Dito wala pang nag-flash sakin.
February 28th, 2008 11:04 PM #33
Kung gusto nyo talaga ng magandang klase.. try IPF.
Super Low Beam XX aka "FATBOY"
Rating: H4 - 12V 60/80W.
Equivalent optical output: 190/150W
This Super Low Beam XX line is what makes IPF halogen technology famous. Known as the Fatboy, this is the beginning of oversized (& over-wattage) halogen bulbs. Huge glass enclosure equals to higher gas capacity & higher exotic gas pressure, as a result, light output is phenomenal. Huge glass enclosure also means wider projection pattern for more coverage all over. As if this is not enough, IPF, which is known for their super heavy duty offroad lighting, integrates a shock-proof stabilizer rod to extend bulb life substantially in harsh conditions. IPF's Super Low Beam series (let it be XX, XXX or X4) always incorporates over-wattage low/high beams, as a matter of fact, their H4 (60/80W) has an equivalent optical output of near 190/150W - the highest rating in its class.
Adding wiring looms can also make a big difference.
ARB Super Loom set.
It is supposed to give up to 25% more power to your existing headlights while using your original wiring. It simply plugs in & reduces voltage drop apparently & allows you to fit higher wattage globes.
- Jun 2008
- 7
- Jan 2007
- 27
September 16th, 2008 05:59 PM #35Bossing, saan naman nakakabili nung yellow bulb na yan and wirings? would it be ok if you could share the dealers info here? or ikaw yung seller? can we know your contact info so we could inquire more info?
TIA
- Jul 2009
- 3
October 25th, 2009 10:03 PM #36
Air Mall or Assembly Grounds * The Rise.
Makati CBD parking
