Results 1 to 10 of 14
November 2nd, 2005 04:34 PM #1
Mga GURU,
Need Help lng po, ano po pa ang reason kung bkit nag ka ganito paint ko sa hood???!! Color black yung ride ko. 2003 mdl plang... regular maintenance din po sya sa paint cleaning...
November 2nd, 2005 05:03 PM #2
Could you post a pic of your hood? This way we could provide you detailed information on what you can do.
November 2nd, 2005 05:38 PM #5Originally Posted by arvic
the cracks are because of the heat from the engine. The permanent solution would be to repaint the hood and install a heat insulator under the hood to prevent heat cracking the paint again.
November 2nd, 2005 06:07 PM #6Originally Posted by ghosthunter
November 2nd, 2005 06:13 PM #7
alligatoring yata ang tawag dyan. polyurethane (anzahl) ba car paint mo? may tendency na mag crack pag lagi naiinitan under the sun and from inside the engine (kung wala na yung insulator ng hood mo). kung acrylic ang paint mo, baka mahabol pa ng rubbing compound. pero kung malala na, repaint na lang solusyon dyan.
November 2nd, 2005 06:17 PM #8
can you give us more details on whether your car has been repainted or not? if so what paint was used? and ofcourse some pics of the affected area so that we may be able to diagnose the problem.
November 2nd, 2005 06:19 PM #9
Oh BTW looks like you'll have no choice but to have it repainted, unless you can live with this eyesore.
yung akin naman... you can add the reverse cam and back-up sensor... pero ADAS - I don't think...
All New Toyota Corolla Cross
