Page 15 of 28 FirstFirst ... 511121314151617181925 ... LastLast
Results 141 to 150 of 273
    Jul 2004
    #141
    Two possible scenario. Nalugi o may tinatakbuhang customer. Alin kaya?
    Dec 2004
    #142
    guys, meron ba kayong kakilala na nagpapaint ng koche? kung pwede sana ung home service para mas madali... papost naman name niya and number kung meron... thnx guys
    Apr 2005
    #143
    uhm quick question lang po...
    newbie here so please be gentle
    having my car repainted by freelance.
    5K = strip ng orig color for hood, top, and trunk + masilya
    10K = repaint (from light blue to dark blue) + clear coat; the sides are ok pa raw so he'll just paint over them
    my question is after browsing thru the threads, puro Anzhal and K92 paints ang banggit dito...no ordinary paints. is it really not recommended to use such paints anymore? (i.e. RM, NIPPON) dapat ba talaga polyethylene paint?
    thanks
    Mar 2003
    #144
    magkano ba 1 gallon ng anzhal (base coat, clear coat and primer) and depende ba sa color yung presyo?
    Nov 2004
    #145
    try ko daanan pag nandon ako sa area nila.nadaan ako dis month lang marami pa clang trabaho. til 5pm lang cla bukas.
    Nov 2004
    #146
    Quote Originally Posted by ownertype
    brod, actually may halong kaba at matinding sapalaran to gagawin ko kasi nga ang mura e.
    Halimaw, punta baka puwede naman makita yung Vitara mo para naman para mawala to agam agam ko sa shop na yan. Sige na please
    pano bro? nakita mo na ba yung pinost kong pics dito sa thread?
  7. #147
    Quote Originally Posted by butchoi
    Is that a complete washover? mmm... freelancer, interesting have you seen his previous work?
    Even if the sides are ok you can't just paint over it, you need to sand it first para may makapitan yung paint, if not it will just peel of.
    Anzaht is good, pero medyo matigas not flexible as Dupont, Sikkens, other newer 2K paints. What paint are you using. You have to ask what preping material your painter will be using...
    Not discouraging you or anything pero medyo duda ako sa magppaint ng kotse mo... shop around more, even tho its cheap, you might be spending more in the long run.
    Mar 2003
    #148
    ano ba ang process sa pag paint(strip to metal) and mga kailangan na materyales para hindi ako mabola ng pintor kapag nag inquire ako? kasi balak ko ako bibili ng materyales and balak ko gamitin ay anzhal. baka may mairecommend pa kayong ibang brand ng 2k na paint na cheaper pero ok din ang quality?
    Mar 2003
    #149
    Quote Originally Posted by halimaw
    halimaw, pa confirm naman kung bukas ba sila. Not in service na yung phone no. na nilagay mo e. Thanks!
  10. #150
    Bat strip to metal? Madami bang kalawang? pag walang kalawang strip to primer pwede na. To answer your question... sanding paper, primer, clearcoat, thinner, masilya... if i miss anything please add na lang.
San Magandang Magpahilamos ng Paint?
