Page 43 of 44 FirstFirst ... 33394041424344 LastLast
Results 421 to 430 of 433
    Jun 2015
    #421
    Quote Originally Posted by Vodka View Post
    just got the Mace Plus. just as i suspected, same "engine block" as the worx hydroshot, but cost optimized
    this thing has the quality level of a branded tool for just P1500. i think it's a steal.
    if there's one negative it's the battery, a small 2Ah so runtime is limited, and the cells are cheap chinese no-name cells
    How's the Mace after several uses? How long does the battery last per charge?
    I saw this in Shopee and they have 1 selling at 1.5k and another at 3.9k. Looking at the ads, both look exactly the same.
    Replacement battery costs 1.5k. Kaya bang i-DIY replace ang cells?
    Feb 2014
    #422
    it's great. i packed up my "real" 220v pressure washer it's not getting used anymore coz it's so cumbersome to use compared to a cordless washer
    but yeah the 2ah is a real limitation so what i'll be doing is convert it to accept ryobi batteries which i'll do after the lazada 30-day return period passes
    yeah you could replace the cells but it's just a 5-cell pack so the best you could do is replace w/ Molicel 2600mah which isn't a huge increase. this tool definitely needs a 10-cell pack
    Jun 2015
    #423
    They have 2Ah and 4Ah batteries on sale. However, presyo na ng bagong washer, hehe.
    Social media made y'all way too comfortable with disrespecting people and not getting punched in the face for it. - Mike Tyson
    Feb 2014
    #424
    still cheaper than other cordless washers. there's an ingco for around 5k without battery
    ryobi around 6k without battery
    Jul 2013
    #425
    My cheapo Fujihama pressure washer works great except the water that comes out also has air....meron bang pure water lang ang kaya ibuga?
    #426
    Quote Originally Posted by Lew_Alcindor View Post
    i do not know,
    but my concern would be,
    at strong pressure, might a spray of pure water dent the metal, more than if it were aerated water...?
    Jul 2013
    #427
    i do not know,
    that'll will the result...
    Oct 2008
    #428
    hello po.
    planning to buy pressure washers sa lazada/shopee for car washing and sidewalk Moss cleaning.
    looking at Powerhouse/lotus brand. Wattage is around 1500 to 2000 watts.
    ask ko lang , pwede ko ba ito isaksak sa extension cords? malayo kasi yong power outlet sa sasakyan and sidewalk.
    thanks
    #429
    Quote Originally Posted by african888 View Post
    hello po.
    thanks
    well,
    extension cords do have maximum wattage limits.
    best to find out, before buying.
    they are usually indicated somewhere in the unit's packaging.
    personally, i would get one with twice the intended gadget's requirements.
    btw,
    if the packaging does not indicate the electrical limits,
    those numbers on the plugs are probably NOT the cord's limits, but rather, the plugs' limits.
    you will probably have to find out the size of the wires used, and consult tables for their respective electrical limits.
    good luck.
    #430
    just bought a lotus 1400w pressure washer. 2900plus with some accesories. ok naman works well. in hindsight dapat pala nag antay na ako ng 10.10 promos
pressure washer brands
