Results 301 to 310 of 635
April 18th, 2009 12:27 PM #301
Hi Guys,
Just to inform you, Frankline Paintless Dent Repair already moved to 31 Examiner St., QC.
It's near the two car washes on the right side if you're coming from Quezon Ave. and past Pacific Blooms when coming from West Ave.
I was one of the last few if not THE last customer to be serviced at the Roosevelt shop. Had my dented door repaired from the puj broadside fiasco and it's as if nothing happened!
Now the only thing to remind of that event is the scratches on my side steps
I highly recommend him! Simple to talk to and down to earth guy.
April 21st, 2009 02:45 PM #302
April 24th, 2009 08:26 PM #303[SIZE=3]Nasubukan ko na yang paintlesss dent repair. OK naman kasi mabilisan ang gawa at mura. Yun nga lang ay siguradong mamumuti yung area. [/SIZE]
[SIZE=3][/SIZE][SIZE=3][/SIZE]
[SIZE=3][/SIZE][SIZE=3][/SIZE][SIZE=3][/SIZE]
- Mar 2009
- 72
April 29th, 2009 03:07 AM #304How much sir inabot ang pa repair ninyo?
Went to their new location and talked with Frank.
Showed him the dings and dents on the rear right side of door and right front fender. Ranging from 300 to 400
Medyo nagulat ako sa dent sa right side ng roof ang quotation ay 1500?
April 29th, 2009 12:06 PM #305
Hi Macmon,
I'm thinking that the reason why the roof repair is much more expensive due to the fact that they will have to pull down your ceiling liner. I've seen him work on dents on other vehicles and it's like good as new after he's done with it.
As for my repair, my damage was practically the entire lower half of my driver side rear door. Cost me P7,000.00! Good thing the damage was sustained "in the line of duty" so the company paid for it. I'm sure it'd cost more if I still had to have it done at the dealership or even at a talyer. It only took a day and if you look at it now, it's almost as if nothing happened.
Frank is the guy PGA calls when them Porches et al need to have PDR service so you know that his service is good but of course, that will come with a little more premium.
Another guy you can check out is Rovic, Frank's apprentice. His operation is located at Auto Camp in Pasig. I'm not sure how much he charges though but it may be cheaper.
Good luck.
- Mar 2009
- 72
April 29th, 2009 11:27 PM #306Thanks Hard Charger for answering my question.
Actually he explained to me that the portion where my roof dent is located is the position of the supporting beam. And as you said, they will remove the ceiling liner to do the PDR. It will take around 3 to 4 hours according to his estimate.
What I am comfortable with is the new location which is near our residence and as you said, very easy to talk to. Actually he found another ding which I did no see.
He even showed me their present "obra" with a "special car" very hard to see when he showed it to me but since he can work wonders with it, I guess he will work wonders with my Advie too.
He is very confident to inform me that it will be as if nothing happened.
thanks again
- Mar 2009
- 72
May 1st, 2009 10:44 PM #308Had my vehicle repaired by Frank this PM. took around 2 hours for 3 dings at the back right door and 1 dent each on the right fender and right front side of roof. Satisfied and Happy with the work.
May 11th, 2009 01:17 PM #309
I learned that Rovic has put up a new shop at 387 Auto Center in Jupiter St. and Richard is left there in AutoCamp. I don't really know the reason behind the split up though...
- May 2009
- 2
May 26th, 2009 03:47 AM #310hi
I'm looking for paintless dent repair skilled workers to work in the middle east, salary plus persentage, please contact me at k.aladdin*hotmail.com
Daming issue ng SU7:grin:
Xiaomi E-Car
