Results 1 to 6 of 6
- Jul 2011
- 10
October 19th, 2011 10:32 AM #1Hi to All,
I just bought a 2nd Hand Adventure GLS Sport and bought it "as is". There's a dent in the hood around 4inches diameter. Now I just heard that there is this PAINTLESS DENT REMOVAL.
How is this being done? How much po ideally? and would you recommend a shop who is doing this?
ADD ON: How about the scratches how can i remove it? meron din scratch na mahaba about 8" long on the hood parang napagtripan before sabi nun seller.
I NEED YOUR HELP PO. tnx! :D
- Mar 2011
- 70
October 20th, 2011 08:46 AM #2Paintless dent removal is simply what the name is...they fix your dent and there will be no repainting if the dent will allow. However a big dent that resulted to the paint removal will have to be painted but the dent removal will be cold or I mean without subjecting the metal sheet of your car to extreme heat what lateros do. Instead, they open up the car part like if it is the door to gain access to the other side of the dent and with skilled precision push the dent to the original position or just like massaging it to the former form. Here in the Phils. the name that always cro0p up when it is dent removal is Frank who operates Frankline PDR located at 31 examiner st. in west triangle in qc. you take west ave and turn to examiner. Tell Frank that you were referred by me so you can have a free estimate.
- Jan 2012
- 1
January 10th, 2012 11:54 AM #3my revo 2001 sr was bump from behind, bale yun lower portion ng door pumasok, pwede bang makuha sa dent removal, no need to repaint na if ever.
March 4th, 2012 01:37 AM #4
Share ko lang. Ni-recommend lang sa ibang car forum.
Before:
After:
Roy
Contact No: 09208910077 / 09088856322
Location: Maceda, Sampaloc Manila. Naghohome service din siya.
March 4th, 2012 02:34 AM #5
It can often be done even at home, I used to do it when I was a teenager...
- Apr 2012
- 186
July 11th, 2012 07:57 PM #6*infested_K
Any idea sir magkano charge niya? Kasi may isang dent yung car ko, ngayon pinukpok from inside the panel. Ngayon, nagkaroon ng 5-7 na 'pukpok' marks naparang pimples sa labas. Kaya ba?
Thank you!
