Results 21 to 24 of 24
- Dec 2017
- 1,018
March 17th, 2018 07:23 PM #21I sprayed it in a paper cup (carefully). Then dip the toothpick. A magnifying glass would help and a painter's tape (blue) so it won't be messy. Precision work required . I use green cross rubbing alcohol to clean the area of the stone chip of any contaminants before doing this.
Wait a day to dry then even it out with a scratch remover (formula 1). You will find that the paint is still a little soft and I find it easier to blend, even out and smoothen rather than a hard dried paint. Can't believe it worked and it saved me lots of $$ buying a stone chip repair/touch up kit from ebay/amazon.
- Jan 2017
- 429
March 18th, 2018 12:02 AM #22What im thinking is putting carnuba wax around the affected area so paint wont stick besied the chipped area.
How to Repair Paint Stone Chips - YouTube
Edit: video for reference
- Dec 2017
- 1,018
March 21st, 2018 09:38 AM #23You can do that too using carnuba besides the painter's tape. I have watched this video before, but, I'm kind of reluctant using a sandpaper because it might affect a bigger area as you sand. A scratch remover is much finer and will do the same job anyway and the formula 1 is clearcoat safe. It's also better that some paint will sort of extend just a little from the chipped area as it helps with the blending.
Anyway, this is what works for me in my situation. Maybe, a larger stone chip might require steps like the video.
- Mar 2017
- 141
April 8th, 2018 11:40 AM #24Got 1-2mm paint chip on my roof. I fear it may rust (valid fear?). Just wondering where to get it repaired (preferrably somewhere south) or is it safe to DIY. Color is snowflake white pearl.
Hello po, new lang po me sa Car Industry Me and my Dad purchased a 2nd hand po na toyota innova...
