Results 11 to 11 of 11
- Aug 2008
- 965
March 21st, 2012 04:15 PM #11A few things - first, try and work the cleaner wax a bit, so you get the most out of it's cleaning action. That is, don't just wipe the product on the paint, but add a little pressure to better remove the grime on your finish. Second, apply in straight passes, horizontally and then vertically - this helps ensure that you don't miss any spots.
For claying, while some people do use a mix of car shampoo and water, I've also heard reports that this can degrade clay, which is why it's usually recommended to use a QD as lubricant. For a good, inexpensive lubricant, check out Optimum No Rinse (ONR) - pinoycarcare.com is selling a 8 oz bottle of concentrate for 510 pesos. You use ONR diluted at 1:64 for clay lube, so you get over 15 liters of lube from that small bottle. You can also use ONR for rinseless washing, as well as QD, so it's a good product to have in your arsenal.
As for adding another product on top, I would think that it'd be a good idea, since Mother's Cleaner wax (and most cleaner waxes) isn't that durable. Optimum Car Wax. a spray wax with durability greater than most OTC waxes, would be a good product to use; Collinite would be another option. I've also heard that Microtex Nanoglos is being reformulated, and that the new version will be more durable, so that might be worth waiting for.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
