Results 1 to 9 of 9
- Feb 2009
- 46
February 10th, 2009 11:13 PM #1good day mga tsikoters, newbie lang ako dito.. tanong lang po, kasi yung toyota corolla ng pinsan ko, pinagamit saken para daw masanay ako mag drive. kaya lang newbie pa din ako mag drive, medyo masikip parking dito samen. ilalabas ko sya ng bahay nang pa-reverse. kaso di ko natancha, dumikit sa wall yung likod nya. light scratch lang naman sya kaya lang halata kasi kulay red yung kotse. ano kaya magandang remedyo dito? thanks in advance..
Tsikot Member Rank 3
- Mar 2004
- 2,053
February 11th, 2009 11:44 AM #2Hard to tell.
First, nararandaman mo na sa daliri mo yung light scratch na yon? Try running your fingernail along or across the scratch. If the scratch catches your fingernail, or worse, if you can feel the scratch from your fingertip, hindi na siya light scratch. Major scratch na yan.
If you can't feel the scratch with your fingernail, then light scratch nga yan.
For light scratches, you can completely eliminate them by using a good scratch remover. Use Meguiar's ScratchX or something equivalent.
For major scratches, you will never be able to completely eliminate them. You can however, minimize them to be barely visible using a good scratch remover. If you're lucky, you can minimize that scratch to a point where only you can see it.
- Feb 2009
- 46
February 11th, 2009 02:03 PM #3thanks to you ess.. base sa sinabi, ang findings ko is light scratch nga lang sya.. mga magkano kaya yung meguiars scratchx? salamat ulet..
- Mar 2004
- 2,053
February 11th, 2009 02:39 PM #4The last time I bought a tube of ScratchX, nasa 700php ata. But that was 3 years ago.
You can get them at any Blade outlet. A bit pricey, pero tatagal naman siya talaga (unless palaging nagagasgas yung kotse..heheh).
You may also want to check out other scratch remover brands like Mother's, Eagle1 and Turtle Wax.
- Feb 2009
- 46
February 11th, 2009 04:24 PM #5salamat bro... ngayon alam ko na... medyo mahal pala no.. baka meron yung ibang tropa ko.. hingi na lang muna ko, maliit lang naman yung scratch.. sayang kasi kung bibili ako ng bago... iingatan ko na talaga magasgasan para di mapagastos.. hehe..
- Mar 2004
- 2,053
February 12th, 2009 10:38 AM #6May kamahalan talaga siya, pero sulit talaga siya. Parang ayaw nga maubos yung akin eh... Pinapahiram ko na nga sa mga office mates kong nagasgasan din.
Yeah, check mo mga tropa mo kung meron sila. Konting konti lang kailangan mo. Siguro a 1-peso sized drop should be enough to treat a very minor scratch.
- Jan 2009
- 74
February 15th, 2009 12:29 AM #7
February 15th, 2009 10:30 AM #8
kung maliit lang yan paps,daan ka na lang sa shop,
we'll remove it na lang at no cost.
(basta maliit lang ha)
help ko sa nagaaral magdrive.
* the_transporter : this is your guide.
www.patpaint.tk
09155057705 09222255122
hope this helps bigtime.
February 25th, 2009 01:28 PM #9
ako din have problems with that light scratches dahil sa mga maliit na bato na madaanan ko going to farm...thanks mga tsikoteers sa mga brand na ni recommend nyo..i'll find that asap..
10 years validity ko yehey , kaya lang sa june pa makukuha physical card :twak2: :rolleyes:
