Results 31 to 40 of 44
February 28th, 2008 11:01 AM #32
February 28th, 2008 11:04 AM #33
ang coilover, isang device lang o integrated ang shocks sa coil compared to the lowering springs + shocks where you get two separate devices.
bro... so you can get an idea on how a vehicle suspension works, please check this link... read it thoroughly... http://www.carbibles.com/suspension_bible.html
aside from that, coilovers allow you to increase/decrease the height of the car using some special tools lang.
February 28th, 2008 11:09 AM #34
some of the things that you may want to know/read about suspensions:
http://www.trinituner.com/shop/coilover.php
http://en.wikipedia.org/wiki/Coilover
http://en.wikipedia.org/wiki/Suspension_(vehicle)
http://en.wikipedia.org/wiki/Shock_absorber
http://en.wikipedia.org/wiki/Categor...n_technologies
February 28th, 2008 05:31 PM #35
pero what would you prefer for suspension? coil-over or shock+coil combo?
kc I cant decide tlga kung, kc konti lng difference, ang Plan ko lng tlga (pero pde pa mag change) is:
REAR:
buy 2 bnew shocks (will be installed by Zee)
Stock coil (will be repaired and Cutted by Zee)
etc (will be done by Zee)
FRONT:
convert/maintain stock Shocks (by Zee)
* yan lng, pero kung konti lng kc difference sa mga bagong shocks, y not ung bagong shocks na lng, hayz,
* salamat, let me read it first, hehe
February 28th, 2008 05:42 PM #36
Add ko na lng din, anu ba maganda na brand ng shocks, pero not too pricey... takiko, paraut, Kayaba, or etc,, wag muna bilstein, di kya maxado, pero how much na rin for that?
balak ko kc is coil over na lng, para mas Ok? isang bilihan na lng, heheLast edited by mackkcam; February 28th, 2008 at 05:43 PM. Reason: MOD
February 29th, 2008 09:51 AM #37
February 29th, 2008 09:52 AM #38
February 29th, 2008 11:03 AM #39
Cge hanap ako, meron sa Zee ng kyb gas type eh, pero tingin muna ako bka mas mura pa aqng mabilhan, Gas shock na lng noh? tpos pwede ko kaya pabawasan ng PSI un, AFAIK ang sabi stiff ride daw pag KYB gas type eh, drop by ako zee this lunch time and mag aask na tlga ako, hehe
pero ok na ba ung plan? shocks na lng ppalitan ko, paparestore and cut ko na lng ung stock springs sa zee, then ung front shocks papaconvert ko na lng sa Zee?
Feedbacks naman sa convert ng shocks ng zee, stiff ba ung ride??? or etc...
Thanks,
OT: di ka nagOnline kagabi noh? inaantay ko reply mo eh,
February 29th, 2008 01:41 PM #40
bro..
first, ok na mag gas shocks ka na today, dahil magpapalower ka din naman.
second, hindi adjustable ang pressure ng KYBs or any brand new gas shocks. ang adjustable pressured gas shocks as far as i know, are those only repaired or converted by zee or cruven. if you take a look at a brand new gas shock, wala syang valve, but if you take a look on zee/cruven converted shock, may valve sya, which they use to fill in with nitrogen, or remove nitrogen.
i still advise going on putol, so if you have other options, DON'T DO IT. you have two options on lowering: install a lowering spring or have the "baso" converted.
on the ride of cruven's converted shocks, ok naman sya... when i was lowered, i had it filled with 70 psi to compensate for the stiffness of my lowering springs. now that my car is on stock height and springs, i'm on 60 psi.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
