Results 11 to 20 of 23
April 29th, 2009 06:42 PM #11
we used weber in painting our car. the painter recommended weber and we agreed without knowing what this brand is. wala naman kasi kaming alam noon. the painter is home service in which sa bahay nya tinarbaho, using the compressor we borrowed from my uncle. k92 sana yung pintura nya kaso nag hesistate kami kasi dito sa amin (cdo) konting pintor pa ang nakapag training ng k92 at baka pag mag retouch na e hindi na same result. kaya weber nalang. we asked around shops about this weber they said maganda lower quality paint but also urethane. yun din ang sabi ni LexTer na may sariling paint shop. noon nga daw di daw ito pinapansin mura lang singil ng pintor 12k lang labor and materials.
in general we weren't 100% satisfied of the work. on the hood and other parts there are small "holes" sabi nya may tubig daw ang compressor. i think he was not a competent painter kasi bat di nya dinrain yung compressor. may mga swirl marks din. nakaka inis. oh well, buti nga hindi anzhal o k92 ang pinapintura namin kasi sayang ang quality ng pintura kung wala namang quality ang pintor. may suki kaming shop pero since were in a budget dun nalang sa recommend ng aircon specialist namin. hahay next time dun na sa suking shop using anzhal.
October 3rd, 2010 11:23 PM #12
try ko muna sa bigbike ko k92, pag ok oto naman susunod ko, ill ost pics din later thanks sa TS nito,
very informative
- Apr 2011
- 3
April 29th, 2011 08:29 AM #14Hello mga Boss,
I'm Painting my car using Anzahl from primer ,Body Color to Top Coat, Question lang ano maganda na base color for White para lumabas or ma enhance yung color para di naman gaano ka Dull yung pagka white nya?, I heard from a friend Silver daw muna yung isa naman Black daw muna. What do you think po? Na primer ko na po and sanded the car at nabilad na to for 2 days ready na for base color? What do you guys think po ?
Thanks in advance.
- Jan 2010
- 126
April 29th, 2011 10:30 AM #15i suggest grey since the anzal primer ir green para madali tumakip ang white over grey color, ginagamit lang ang siver para mag special effect usually ang pearl / metallic colors not on solid white colors and just make sure na you have enough primer thickness after sanding lalo na yung may masilya para hindi manilaw ang top coat mo
- Apr 2011
- 3
April 30th, 2011 01:46 AM #16Thank you sir Raul Tuason for the advise. That really makes sense..For Jet Black naman po grey din kaya maganda? Thank you again
- Jan 2010
- 126
April 30th, 2011 10:01 AM #17
- Apr 2011
- 3
May 1st, 2011 09:13 PM #19Thanks Sir !
Post ko dito magiging result nung project ko ginagaya ko kasi yung color ng MK1 Pajero 86 na ginamit ni sonauto sa Dakar kaya yung hood hangang door is white na may stripe na red and grey. then yung half jet black na... Thank you again sir dami ako nalaman bago... Mabuhay po kayo dito sa Forum for helping out people who wants to learn and not just save money.
February 28th, 2012 12:08 PM #20
I'm having some painting done on my ride. Try ko itong K92 if ok.
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
