Results 11 to 20 of 25
November 13th, 2002 06:06 PM #11
Thanks bossing Twice ko lang kasi ginawa. Try ko rin yung vinegar solution.
- Nov 2002
- 1
November 25th, 2002 01:05 PM #12what's the composition of the vinegar solution to use for windshields?
tks!
- Nov 2002
- 34
January 13th, 2003 05:07 PM #13How can we prevent water spots?
This is my very serious problem. (Edited ko na sorry!)
January 13th, 2003 05:17 PM #14
I also experience the same prob before pero now meron akong remedyo. I did a 3 step detail sa car ko. Then I make sure na at least once every two weeks I shampoo the car. Minsan kita ko may water stains eh. I just washed my car with water, dried it and used cleaner wax. Aba the stains wont come away. Pero nung nag shampoo ako ng car then cleaner wax then top off with carnauba nawala ang water stains. After that I made sure I shampoo my car at least every two weeks. Then apply cleaner wax and carnauba. No more water stain problems now. Hope this helps.
January 13th, 2003 05:42 PM #15
Erick: Common sense lang... if you wax your car often, you'll always have a sacrificial layer for contaminants to settle onto. It's much easier to remove a spot that has stained the wax surface than remove a spot that has etched onto the paint.
In addition, never let anything accumulate... if you wash your car, dry it... this is especially true during the rainy season, most people are just too lazy to wash or maintain their cars... Not understanding that the constant acid rain contact requires a more frequent washing and waxing regimen.
It's like asking "how can I keep my ashtray from filling up!?" obviously, clean it out often... the more people who'll smoke and use that ashtray, the faster it fills up, so you have to clean it out more often...
By the way, please don't type in all caps. Net courtesy... Thanks.
January 13th, 2003 05:55 PM #16
Erick, if you do regular maintenance such as shampooing and waxing, it becomes easier everytime you do it. Kasi dirt wont accumulate that much. It just takes me around 45 min to finish my car from shampooing to waxing.
- Nov 2002
- 34
- Nov 2002
- 34
January 20th, 2003 09:56 AM #18This is what I did.....
I washed my car using Polyglaze autowash then after drying.....I applied carnauba car wax only on the affected portions where there are water spots and I let it stay for 30 mins and then I wiped the wax off........ Nawala yung water spots!!!!! YAHOOOOO!!!!
Mula ngayon I'll wash my car 2 -3 times a week and wax it once in 2 weeks.
Di ako nakabili ng 3M finish restorer kasi ang mahal. Biruin mo 350 isang maliit na bottle?
Thanks sa mga replies and tips.
June 3rd, 2007 03:58 PM #19
many many thanks mga ka-tsikot. Problema ko din yang pesteng watermarks na yan. Extremely helpful ang inyong mga sharings. Salamat ulit!
June 6th, 2007 11:52 PM #20Originally Posted by ;13363
Bro. ask ko lang on what kind of vinegar ito, is it the vinegar like Datu Puti???
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
