Results 11 to 20 of 27
    Quote Originally Posted by niwrad
    where can i get euro rear foglamps for pizza?
    how much?
    meron ba nito?
    btw ung headlights washer ng pajero, un ba ang pang pizza rin?
    Try mo sa el dorado... usually nasa 3k-3.5k a pair. Iba ang headlamp washper ng pajero.. flat yun... for the pizza medyo curvy siya ng konti.
    sir slayer,
    san ung el dorado? how does the rear foglight look like?
    tnx for the info...
    mbt , M3 side mirrors , yung side mirror niya copied to fit any car , universal models ito . or the Ganador side mirrors .
    I think what mbt meant is that M3 mirrors looks rather inappropriate. M3 is for BMW only. If you want the Euro look, get the appropriate oem Euro spec parts for your vehicle make.
  5. zz is offline Verified Tsikot Member
    Join Date
    mr.niwrad,
    its the garnish part of ur trunk. L & R yun. some people use it for brake light but thats the legit rear fog light. plus get the OE magnetic switch instead of just tapping them to ur park light
    gusto nga maging euro look ang japanese car niya di ba ? well that means walang euro specs or anything kaya example ang M3 , nakakita ka na ng M3 ? marami ng nag change ng side mirrors ay M3 style dahil maganda ito , kung pang BMW lang ang M3 mirrors then huwag na niyang i convert to euro look at all dahil Lancer kotse niya .
    like the Ganador , copied ito sa NSX pero marami gumagamit dahil maganda but hinde NSX kotse nila .
    zz,
    so when i want to make it as my rear foglight, im gonna let both light at the smae time? or just the left side should light?
    Quote Originally Posted by DSM619
    check out what 1.8 posted... IMHO it would be a proper way in going for the EuDM theme in a Japanese car.
    meron naman rear fog, headlight washers and the roof antenna for the Euro Lancer. ...like what has been posted by others ... Euro spec accesories/parts for the Euro Lancer.
    M3? Yep... everybody knows what it looks like ...don't worry I know what a BMW M3 looks like
    Too each his own... :roll: :roll: :roll:
    oh well then stick to the OEM more better , euro Lancers differs in specs only and not on the looks , or minor on the looks . a set of clear side marker should do the job .
    Quote Originally Posted by 1.8T
    What should i add to my car to have a euro look?
    btw my car is lancer pizza...
    europlates?, white side marker lamps whatever you call them. sometimes you can change the headlamps para e-codes, "european codes" iba kase ang beam pattern ng european headlamps, mas malake ang sabog hindi katulad ng u.s specs. dito sa u.s. we can get the e-codes headlamps pero it's technically illegal.
    ano paba mga tol?
    montero ko na may e-code projectors. imported to the US from Germany. check sig for mo pics
euro look
