Results 1 to 10 of 48
- Aug 2003
- 9,720
November 12th, 2003 05:59 PM #1last last week a bought a liter of gaas to try and clean up the engine bay...wouldn't you know it -- ayaw pa rin matanggal! any tips?
November 12th, 2003 06:12 PM #2
engine degreaser would do.
or bring it to chieffy kung medyo tinatamad ka
November 12th, 2003 09:11 PM #3
Avoid gaas. Yes, si Chieffy maraming 3M engine degreaser. hehehehe.
November 13th, 2003 10:29 AM #5
kung nagtitipid, one sachet ng joy dishwashing solution lang (amoy kalamansi ang makina mo afterwards!). just dont forget to wrap plastic in your alternator, distributor, carburator and the sparkplugs if you dont have aircompressor. do it under the sun para madali matuyo. happy washing!
BANNED BANNED BANNED
- 3,790
November 15th, 2003 10:38 AM #6kung heavy buildup na ang engine gunk and other deposits....highly recommended na gumamit ka ng engine degreaser. Spray it liberally and soak for at least 5 mins (depende sa brand na nakuha mo minsan longer than 5 mins ang nirerecomend nito). Then rinse, power sprayer is optional. As mentioned above, protect those that need to be protected. Kung kulang pa rin, then I usually use some kerosene placed in a spray bottle ang attack the portion lang that needs additional cleaning...minsan an old tooth brush will help in clearing the stubborn dirts.
After the kerosone, rinse again with water and then I'll have it sprayed with the joy solution to remove the gaas, then rinse again with water.
Kung mga portion na nacover but needs to be cleaned din...manual na ang linis nito with a tooth brush...but I use WD40 instead of gaas or degreaser (although degreaser kung me natira pa would be better din)...I spray the WD40/degreaser on the tooth brush and brush away the dirt with it.
just my 2 cents.
November 15th, 2003 11:42 AM #7
Pare, dalhin mo nalang sa mga professionals. ewan ko ba, basta galing dun the engine seems to be a lot cleaner.(alibi ng mga tinatamad maglinis...hehehe)
November 15th, 2003 12:02 PM #8
Maybe we could help you. Call BigBerts Professional Detailers at 415-0979 and look for David or Vince
- 3,790
November 16th, 2003 10:43 AM #10yes, nakascrew sa loob ng engine ang glowplugs and its contacts are not sensitive like the spark plugs kasi its not a high voltage line. The glow plug is simply some sort of a heating element...standard 12V would do the trick.
Sa diesel the only thing sensitive enough would be the dip stick hole and modern day alternator wherein the voltage regulator ic is inside the alternator. For such, you have to make sure that the dip stick is plug properly to its hole so no water gets in and the alternator is balot sa plastic (a plastic bag should be fine).
Make sure that when you spray with water you don't concentrate too much water pressure on these mentioned areas. Yung portion rin the iyon ang unahin mong tuyuin after the final wash.
I have noticed that the meguires to an excellent job on the metalic prortions of my engine....they look very much like brandnew after the cleaning....but use it properly as directed!
my 2 cents.
Monk-owned R53
