Results 21 to 30 of 39
July 15th, 2017 06:09 PM #21
^^^ best results are achieved with a newly waxed surface and using de-ionized water. BUT with a relatively clean surface (just washed) and ordinary tap water almost 90-95% of the water can be removed. even when the car is washed using only water (no shampoo, when you just want to get rid of daily dust) this method still does helps a lot. less water droplets to wipe off means less time and effort to dry rhe car.
btw, i prefer mf cloth over chamois. parang mas madali kasi, less force needed to move the cloth over the surface.
- Oct 2016
- 41
July 20th, 2017 07:26 PM #22More than a month or almost 2 months siguro
Sent from my SM-G930F using Tsikot Forums mobile app
July 20th, 2017 09:09 PM #23
- Oct 2016
- 41
July 20th, 2017 09:54 PM #24Nakalimutan ko na yung tatak na nakalagay sa mismong bottle pero liquid wax siya with carnauba. Kasama sa isang kit from Mitsubishi.
Or possible din kaya na masyado ng contaminated yung paint surface?
July 21st, 2017 08:59 PM #25
try mo nang gumamit ng ibang wax sir.
and you may take your time reading here for tips; https://www.tsikot.com/forums/auto-p...tenance-77542/
- Oct 2016
- 41
July 22nd, 2017 01:52 AM #26Naalala ko na Dia Plus something ata hahaha!
Anyway sige salamat po sir!
- Oct 2016
- 41
August 29th, 2017 01:39 AM #27Anyone here uses Microtex Elitr Drying MF?
- Jun 2016
- 32
October 17th, 2017 10:42 PM #28
I do. It works well but I tend to blow the water off away first to lessen the needed contact time between the towel and the paint. However, if an outlet is not available (condo parking, for example), I just try to gently pour water or host it off and let gravity (and the coating/wax) work to lessen the water that I'll need to wipe off.
- Dec 2014
- 25
October 23rd, 2017 10:13 PM #29
- Nov 2017
- 1
November 21st, 2017 01:15 AM #30hello, I always use the products of the brand Mafra. They have several good products to dry your car!
They are leaders in Italy and their products are very good. If you want, you can try it
