View Poll Results: do you use windshield water solution?
- Voters
- 41. You may not vote on this poll
Results 31 to 40 of 49
November 16th, 2007 01:30 AM #31
November 16th, 2007 02:45 AM #32
Subukan ko nga ang baby shampoo.
Share ko lang, re: baradong nozzle. Nangyari na sa akin na nagbara ang nozzle dahil sa impurities or foreign objects mixed sa tubig. Nakakainis! Nangyaring bumara ito kung kelan pa naman pagtapos umulan at kailangan ko mag-wiper para alisin ang mud spray galing sa sasakyan na sinusundan ko tsaka walang tubig na lalabas sa nozzle. Ayun, smudgy yung windshield ko. Buti na lang di ako na-aksidente. Inis talaga! Kaya ngayon, I make it a point na gumamit ng pinong strainer tuwing maglalagay ng tubig sa reservoir.
November 16th, 2007 11:09 AM #33
You can clean the washer nozzles with a needle, and also aim them using the same needle while you're at it.
The newer nozzles with a slit in place of the pinhole can be adjusted using a razor blade or fine screwdrivers.
November 16th, 2007 12:00 PM #34
i also use dishwashing liquid.. few drops lang does the job..
i also used to clean the windows using RainX..medyo horror lang kasi nung pumatak sa pintura natunaw top coat.. kainis!
November 16th, 2007 12:28 PM #35
dishwashing liquid din...ok pag umuulan...pero pag natuyo sa araw malagkit kaya wash na ng windshield pag-umaraw na...
November 16th, 2007 01:10 PM #36
I use car shampoo with water solution during the wet season. During summer, I just use water.
November 16th, 2007 02:00 PM #37
ung windshield washer ko ayaw sumirit o bumuga ng tubig??.. ano po kaya problem nun>?
November 16th, 2007 05:51 PM #38
Might be barado nozzle tip mo,have it declogged by pin,sundutin you lang butas.If not there,check the hoses baka may mga leaks,again if not,pump motor na nya or wala tubig resovoir tank nya
In using washer solution, not yet decide pa ko,but thinking of Rain x by autogard,ito yung pinapahid lang sa glass once every month,available sa Ace,handyman,diy,etc.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
