Results 1,821 to 1,830 of 5910
April 27th, 2006 11:39 PM #1821
relax lang flakez... explain mo na lang sa erpat mo. Or pabasa mo na lang dito.
Tsikot Member Rank 3
- Apr 2004
- 663
April 28th, 2006 09:09 AM #1822Meron ako nakita na duster sa SM na parang CCD at waterblade na parang yung sa CCD din. Kasama ng mga demo products nila. Pati microfiber meron. OK kaya mga ito? Yung duster, instead of wax some sort of silicon daw ang nakaembed sa strands niya (less than P1K). Yung waterblade, silicon construction din daw. Yung microfiber, you get 4 towels for P400+.
April 28th, 2006 02:32 PM #1823
Originally Posted by frankosiz
kaso I'm not gonna wash my car directly under the sun.
April 28th, 2006 02:40 PM #1824
RafRaf: Nothing beats the Original California Car Duster, think of it as an investment - it will last you around 5-6 years even without washing, just don't drop it. Sa Microfiber naman, get the Microtex available naman to locally.
BTW, Autoplus, the local distributor of Mothers will also sell CCDs, abangan mo na lang sa transport show, I think they'll have a booth.
April 28th, 2006 03:04 PM #1825
nagkaroon nang bird poh yung car ko. Matagal sya bago nalinis at natanggal yung bird poh mga 1 week siguro hindi kasi napansin eh. Hindi kasi nagamit.
Nung nilinis nagkaroon na nang bakat yung bird poh.
Paano sir sya matatanggal.
Thanks.
April 28th, 2006 03:19 PM #1826
yikes.. baked and etched already into the paint. that's one of the reasons why I don't let those sit on the paint for too long.
depending on the severity, polishing (DACP) or several applications of a scratch remover would greatly reduce the appearance of that defect. im a bit wary though that it might have eaten already through the clear. just make sure to rewax the affected part afterwards.
what i did before to get rid of a similar but extensive defect is to wet sand it. but mind you, I don't like to recommend wet-sanding to everybody because it thins the clear considerably and you have to be skilled and confident enough with your buffing skills to remove the sanding marks left by wet-sanding.
April 28th, 2006 03:23 PM #1827
mukha nga it already eaten the clear coat
Pwede na ba yung 3M scratch remover? then I will wax it off na lang.
April 28th, 2006 03:28 PM #1829
Originally Posted by CLAVEL3699
good luck. hope this helps.
Depende po on when dumating yung LTO registration or ano Registration date sa CR/OR nyo. Mine, I...
1st LTO renewal after 3 yr registration
