Page 140 of 296 FirstFirst ... 4090130136137138139140141142143144150190240 ... LastLast
Results 2,781 to 2,800 of 5910
    #2781
    mapag-ipunan nga ang mga yan
    Sep 2005
    #2782
    ingat sa Rain-X.. alcohol base sya.. based sa experience ko.. hindi maganda effect sa wipers..
    Aug 2008
    #2783
    up on that, pag napadami lagay mo skip to my loo ang wipers mo and if you apply rain x buff it really good kse magkakaroon ng crystals s windshield mo ung prang patak ng ulan pro d mo matanggal ng kamay hirap explain e
    #2784
    then what would be the best windshield treatment? medyo nakakainis kasi pag may spots eh.
    then eto pa, yung fx namin, yung driver side, squeaking ang wiper. kahit bagong blade, tumutunog, parang may gasgas or something. help naman po...
    Sep 2005
    #2785
    pa buff mo yung windshield mo.. sa Big Bert's may service silang ganyan..
    Aug 2006
    #2786
    nasa last stage na ako ng detailing sa auto ko., ano magandang pang tangal ng swirl? TIA
    #2787
    Mothers Step 2 (sealer & glaze). tanggal ang swirls dyan.
    Jul 2006
    #2788
    Quote Originally Posted by nat2x View Post
    may treatment ba for rubber? yun sa salamin ko kase yun rubber, nag fafade na parang white,. anu magandang gawin sa ganun?
    Quote Originally Posted by Picard View Post
    Try applying armor all
    Avoid Armor All at all costs.
    I can tell you, for the money you'll spend, Meguiar's Exterior Trim Detailer works wonders on body plastics and rubber compounds. I was so impressed I had to buy two. Almost used up the first one, going to use the second can (aerosol) on the new car to get the old faded trim back to its former glory.
    Best part, is if you accidentally spray the other bits you don't want to spray, just wipe it off.
    My friend bought THREE cans. This was out of stock the last time I checked my local auto parts store.
    Only thing, is you should only spray this in a well ventilated area. It's an aerosol can, the smell/fumes can get a bit overwhelming. Other than that, I'm sold on this product. And no, by the way, you cannot spray this onto a towel and use the towel to apply the product. It has to be sprayed directly onto the car.
    Avoid Rain-X or any windshield treatment products. These make your windshield wipers chatter, more so if your windshield is dirty and/or pitted. Nothing beats a truly clean windshield, free of any oils.
    For my purposes, I wax my car's windshield on occasion. It does not rain much here in California so there's no need, but when it did, I did not have to use the wipers a lot because the windshield is kept clean. It also helps I have new glass
    For rubber protectant, I use Aerospace 303. It has an SPF 40 just like sun tan lotion for your car. Used it on the interior, weatherstripping and a little bit of the engine bay (since it cleans it up nicely too). Which reminds me, I need to get another bottle...
    Mar 2005
    #2789
    how about rain clear gel?
    Jul 2006
    #2790
    Quote Originally Posted by jmpet626 View Post
    Is it a windshield treatment product?
    Nov 2007
    #2791
    I've had good results using the Glass Science Glass Scrub and Rain Clear Gel.
    Nov 2007
    #2792
    Quote Originally Posted by mbeige View Post
    Hi mbeige,
    I got curious.... hope you don't mind if i ask why it should be avoided at all costs
    Aug 2006
    #2793
    ask ko lang, ano ang meron sa wash over sa ibang detailed procedures?
    Jul 2006
    #2794
    Quote Originally Posted by jonjon_u View Post
    Hi mbeige,
    Do a search on Armor All, it's been discussed many times in the archives.
    #2795
    I did some search here on Armor All but I can't see much about negative things discussed about the product
    Nov 2007
    #2796
    Quote Originally Posted by attyallanlatras View Post
    Hi. I've already done a search in the various detailing fora before I posted my question.
    Admittedly, it is *not* a favorite product line. However, it is worthy to note that a search would reveal that a number of Autopia members nevertheless use Armor All. Here are some threads/posts:
    http://www.autopia.org/forum/car-det...rmour-all.html
    http://www.autopia.org/forum/382787-post3.html
    http://www.autopia.org/forum/pro-det...ero-x5-h2.html
    Experiences given by these people piqued my curiosity as to why it should be avoided "at all costs".
    Mar 2005
    #2797
    ako din matagal longevity ng rain clear and madaling i apply. Ang nakita ko nga lang na downside sakanya eh natunaw ung Lake Country na Foam pad ko nung ginamit ko na pang apply ng rain clear. Ngayon gamit ko na lang eh Sponge sa pag apply.
    Apr 2008
    #2798
    Hi Guys,
    after dusting the car, Insted of using a QD i'm using a MF towel dump with water to wipe the car.
    my question is, the MF towel dump with water will deminish the effect of the wax?
    Sep 2006
    #2799
    Not necessarily as long as you use tap water only. I've read somewhere that chois strips off wax. Some QD also strips off wax.
    Nov 2007
    #2800
    Quote Originally Posted by Hardinero View Post
    Hi Guys,
    I humbly suggest that you still use your quick detailer, not because of its effect on the wax, but because you would rather prefer to minimize the risk of putting spiderwebs on the paint.
    But to be on topic, paki-check mo itong related article sa Meguiars forum. It's about the effect of those products or processes that require you to "touch", or do some wiping on, your paint.
    http://www.meguiarsonline.com/forums...44&postcount=5
    Hope this helps.
