Results 1 to 19 of 19
    Sep 2008
    So I have a 2 month old black Chevy Cruze. I chose black thinking that the paint reflections would be mirror-like. However, as with most factory paints, there is a little bit of orange peel in the paint. It's not perfectly flat so the reflection is not that good.
    I've read that wet sanding and buffing is the solution to orange peel. However, most experts wouldn't recommend wet sanding factory paint because 1) it's thinner than custom paint jobs, and 2) the paint is harder, hence, it would be difficult to buff off the wet sanding marks.
    So, an idea crossed my mind.
    Why not put on additional layers of clear coat on the factory paint? That way, you would have more thickness in clear coat and thus it would be safe to wet sand.
    Is this such a crazy idea?
    Another question: Have any of you actually wet sanded factory paint, and would you say it's safe to do so?
    Hoping the detailing gurus in this esteemed forum would give their ideas.
    Hi bro! :clap: Mabuti at naisip mo yan. Natutuwa akong maalaga ka sa paint ng Cruze mo
    Yang question mo, pwede yan. Meron akong friend na ginawa yan sa Civic FD nila. wet sanding muna tapos layer ng Anzahl Clear coat. Black din kasi yung FD nila. Ganda ng kinalabasan. Wala orange peel tapos matibay yung clear coat.
    Sep 2008
    Salamat sa reply, sir SG! At may pictures pa!
    At least alam ko na na ginagawa talaga yun. Siguro hanap lang ako ng talagang competent na shop.
    Aug 2007
    *SG - FD ni rafael? Hehe. Kintab nga niyan sobra.
    Mar 2005
    Yung orange peel kasi is nasa initial layer ng clear coat so kung papatugan mo ng another layer ng clear coat i wewetsand mo yung new clear coat till ma reach yung border ng 1st layer and 2nd layer at dun mo papantayin. Pwede kaso mahirap siya at sobrang labor intensive.
    Ganito din paint ng Sta Fe namin grabe orange peel pero sumuko na ko hinayaan ko na lang kahit nakaka ilang kasi yung reflections blurred.
    Jan 2010
    Quote Originally Posted by electone View Post
    if i were to choose bet. OEM look with little orange peel or repainted look na walang balat suya, i d go for the oem,maybe wait for couple of yrs or go to a good detailing shop im sure they can help you with a better option with the gloss, iba pa rin ang original look para sa akin, sayang naman kay bago ng auto mo
    Sep 2008
    Quote Originally Posted by jmpet626 View Post
    Ang pagkaka intindi ko kasi hindi na aabutin yung original o factory coating ng clear coat kasi dadagdagan ko ng up to 4 layers of new clear coat. Pag winet sand ko yung bagong lapag na clear coat, hindi na aabutin yung factory clear coat.
    Tama ba?
    Pero tama ka, masyadong labor intensive, kaya nagdadalwang isip ako.
    Quote Originally Posted by GunnerJam View Post
    Yup. Pina washover na nila nung march kasi nabangga. Tapos final buffing daw last month. Di ko pa nakikita yung result. Pero sobrang kintab daw
    Sep 2008
    Quote Originally Posted by raul tuason View Post
    To wait for a couple of years is also a very good idea. Thank you sir.
    Aug 2009
    hello, its not a crazy idea if you ask me, i have a few friends that have gone through the same process but their reason was to have their car covered with PPG Ceramiclear because they don't want to get too much swirls since they are too busy to take care of their cars and until now their cars are just washed by the usual car washes down the corner, and honestly it turned out quite well, they have a thicker clear coat which would offer more surface for paint correction and until now its still pretty much swirl free, but what they hate about it is that they spent about 20 to 25k just for that, its pretty much already like a washover price i dunno if its because of the clear coat, but i guess it all depends on how far and how much you would go for your new car, i mean my Revo has a Ceramiclear clear coat but honestly i find it a little impractical, why? its true that it has a really tough scratch resistant clear coat but once i get gash by a tricycle its pretty much also straight to the metal, the cost of repairs would also be higher, so in my case it wasn't worth it since the Revo was just a daily drive and semi delivery car, but in my friends' case with their BMW and their Camry it was well worth it because honestly it still looks as good as new even 4 years after, so bottomline for me, if you have the cash to spend and want that extra wet look and more paint to work defects then i would go for it, but if you're on a tight leash then i would just save the money and save it for a wash over, but if its me i don't really find it worth it if you just put on regular clear coat since if you add just a little more you get the really tough ones
    Sep 2008
    *madkatz
    Thank you for your reply. Very helpful insights there.
    Will the regular swirl removers and rotary buffer be able to remove swirl marks off PPG Ceramiclear? Thanks for telling me about this tough clear coat.
    Jan 2010
    *madkatz
    para maging pulido ang pag pintura kailangan strip lahat ng mldg. door handle,para sa 2 month old na auto'' ARAY '', sir baka di maibalik ng tuwid ang maga mldg,iba kasi ang lapat ng mldg pag bago lahat ng mldg clips at baka ma void ang waranty ng auto mo pag nagluko ang power door locks at power window at yung sinabi ni sg na civic nabangga pala kaya okay lang na ipa clear niya ang buong auto, para sa akin sayang pera
    Parang gusto ko ipatanggal ang orange peel ng Ranger ko, nagtanong na ako sa paint shops and wet sanding + re-apply ng clear coat. Any recommended shops?
    Quote Originally Posted by cdv View Post
    sir ginawa kuna sa trooper yan sobrang kintab parang pang carshow ang kintab......orange peel di gaano maganda sa dark colored car...a reputable detailing shop can do it with out wet sanding usually mga 3-4 steps detailing can do the trick....try to ask at bigberts thread...IMO
    Jan 2008
    ako mas gusto ko yung may orange peel ng konti.. kasi talagang bago tingnan.. unlike pag sobrang kinis parang pinturado ang dating...
    Quote Originally Posted by dh0n View Post
    Ah okay, sana nga kayanin ng detailing. Thank you, dh0n.
    Yeah but I think it doesn't look nice on a dark car. Well, we all have our preferences.
    I don't think wet sanding + re spraying of clear will do any good.
    Maybe using a heavy/med compound will remove/lessen it.
    Quote Originally Posted by ronki View Post
    Oh okay. Any specific product reco?
    question lang mga sir, ano ba cause ng orange peel effect? dahil ba sa planta ang painting ng brand new cars kaya orange peel anf finish at di kaya gayahin ng paint shops? saan ba pwede magpa repaint ng door na magiging orange peel effect and finish para same as the other doors/panels na orange peel oem effect?
Crazy idea
