Results 11 to 20 of 20
- Nov 2003
- 190
December 27th, 2003 11:27 PM #11Actually, a good old fashioned pipe cleaner would also be handy. You know, the ones that your lolo would use to clean his tobacco pipe. They're actually short pieces of wire covered with bristles or absorbent material/cloth and consequently become pretty effective miniature brushes. In fact, these are sometimes used to make wire sculpture.
SM has this in the Men's Department....in the counter where the lighters are sold. Or try the Fuma! counters.
- 259
December 27th, 2003 11:38 PM #12i use my pressure washer to clean the tail lights. it can reach the areas that the brush can't reach.
January 3rd, 2004 01:53 AM #13
i learned a few things about this recently. my front cornering lights had turned amber due to the bulb melting some of the plastic.
i tried bleach first (overnight). it didn't work. couldn't find liquid sosa, so i tried muriatic acid :D it didn't take out the amber, but it did strip the silver coating from the lamp assemblies
now i'll have to spend 1000 to replace the two, non-OEM pa yun. :P
January 3rd, 2004 04:29 AM #14
safe for all ba yung mga mentioned above? ksi yung sa friend ko yung acord 94 headlights niya pinalinis niya, linagyan ng glass cleaner or some chemical, habang linilinis, natanggal yung chrome sa ilang part nung headlamp. is this because luma lang yung car/healamp?
di kaya maninilaw yung headlamps pag vinegar ginamit? hehe thanks thanks
January 3rd, 2004 09:33 AM #15
the "chrome" part is not chromed or anything, it's just plastic reflectorized coatings which are VERY VERY sensitive to anything from physical contact to chemical contact (even water can scrape it off depending on material type)... it's best not to touch that part other than soft cotton towel with no pressure... Older cars (like my 123 benz) has a more metallic coating which is more durable but less reflective...
January 3rd, 2004 11:33 AM #16
.. yeah.. that's what happened to me.. that "chrome" is reflectorized plastic and the muriatic acid took it right off (without any physical rubbing action) :O
January 3rd, 2004 03:26 PM #17
yup, si Blackmagic, he poured a glass of water and shook the headlight assembly lang (not hard pa!) and the reflective coating came off
January 10th, 2004 01:13 AM #18
so talagang yung lens part lang na clear ang dapat linisin dba?
problema sa mga honda headlamps bilis madumihan. ibang makes naman di ganyan. bat kaya? parehong stanley naman ah.
January 10th, 2004 10:19 AM #19
Dragon, i think it has something to do with where the lens exhaust holes are, the Accord, BMW E36, AE111 Corolla, RAV4 are pretty much a dirt prone model-headlight assembly
suzuki #2... kahit malayo... heh heh.
Car Sales Data (2023)
