Results 71 to 80 of 130
October 12th, 2020 11:32 AM #71
Found rat poop in my car battery when I open the hood which is park in the garage and im using it only on sundays any tips?
October 12th, 2020 11:39 AM #73
October 12th, 2020 11:45 AM #74
October 12th, 2020 11:50 AM #75
The rat here is as big as a cat what im doing right now is to clean it everyweek the engine compartment hoping that cleanliness will shove them away I dont want to harm them because they might get revenge that is always the case with rats.
October 12th, 2020 11:52 AM #76
+100. Keep the hood open and if possible have a light on all night. Kung pwede sa may hood yung light mas ok. Kahit 1 watt na led bulb lang, that is only 12 watt hours x 31 = 0.37 kwh per month. Isabit mo ilaw sa hood mismo para buong engine bay maliwanag.
Also baka galing sa labas yung rat. Saan sila pumapasok? Baka yung gate mo open sa baba (grills?) you might consider blocking the grills with chicken wire.
October 12th, 2020 11:54 AM #77
October 12th, 2020 11:55 AM #78
October 12th, 2020 11:59 AM #79
October 12th, 2020 12:04 PM #80
That's just their natural instinct to chew on things and not because they're on a war path against you personally because of what you did to them or to their kinds.
As for the trap and bait. They just learn from experience what to avoid or not.
The current gen Kicks e-power is basically a compromise, as the body+chassis design came first...
2025 Nissan Kicks
