Results 1 to 6 of 6
- May 2009
- 5
August 17th, 2009 11:32 PM #1Mga Sir: May tanong lang po ako? why car paint bubbles? considering po na karerepaint lang ng auto. may bubbles po sa may hood at sa may roof. bihira lang po gamitin at may sariling pa pong garahe.
August 17th, 2009 11:39 PM #2
The metal was not prepared properly. Some old rust could have been left behind which accelerated the formation of new rust under the paint.
When repairing rust damage, the metal has to be cleaned of old rust and a rust inhibitor chemical applied which will protect the metal from forming rust. After that, paint primer is applied, etc.
August 18th, 2009 02:58 PM #3
Sir,
panu naman po pag Fiberglass ang dame nyang parang butlig butlig?
2 times na po namin binabalik sa kasa backjob(front and rear skirt) pero yung side skirt hindi naman po ngbububles, ung front and rear po pala copy lang na skirt hindi po orig sa kasa lang po namin pinapinturahan para walang color problems pero ayun naman ang problem niya. haayyyss.. mga 1 year po bago lumitaw yang mga bubbles na yan sir..
anu po kaya ang problem?
salamat po
- Jan 2005
- 445
August 19th, 2009 10:31 AM #4Depende din kasi sa weather yan, dapat mainit ang araw para di bumula, nag aabsorb kasi ng moisture ang paint pag malamig, unless oven dried painting yan
August 19th, 2009 11:35 AM #5
Fiberglass panels (resin) tend to bubble especially when exposed to heat (and painted a dark color). It is possible the resin is not fully cured.
If it's not the fiberglass, it can be the painting itself. The paint layers was laid down too thick and was still wet when the next layer was applied.
- Jan 2008
- 29
August 19th, 2009 11:47 AM #6Mga sirs,
ako din po yung car ko meron na mga bubbles,kailangan po ba scrap to metal repaint o kaya na nung hilamos lang. thanks.
Traffic!
