Results 11 to 20 of 20
October 11th, 2006 05:57 PM #11
tail light garnish? and OEM foglamps what does that look like? whats AFAIK pla? thanks
October 11th, 2006 06:01 PM #12
hmmm. medyo.
magandang skirts sana is micro mini tapos may slit.... ayun, boto ako dun.
*deathlance: afaik, means as far as i know. OEM foglamps are yung parang nasa lancer MX. maliit sya na bilog pero high powered. you can check them out sa mga casa o sa El Dorado.
rear foglamps are also ok, para hindi OA yung look.
*otep: yung tail light garnish ba na sinasabi mo is yung kabitan ng plate number sa likod? yung reflectorized?
October 11th, 2006 06:02 PM #13
See the pictures posted above. Naka-OEM foglamps yung Lancer ni impulzz.
Naka-tail light garnish din (the red things mounted on the trunklid which widens the taillamps). Hindi po ito yung lalagyan ng plaka (hindi ko type yun, hindi terno sa plastic ng taillamp lens).
Tail light garnish ay same din ng rear foglamps. Wala nga lang bulb. Dummy lens lang.Last edited by OTEP; October 11th, 2006 at 06:04 PM.
October 11th, 2006 06:09 PM #14
got it fafa otep. afaik, those rear garnishes are stock for models 99-00. yung sa akin nga gusto kong palagyan ng bulb para mabuhay eh.
pero di na lang, what i did is to put in a rear plate garnish na lang.
October 11th, 2006 06:12 PM #15
Sa pinsan ko kasi '97 kaya pinalagyan niya pa.
October 11th, 2006 06:32 PM #16
unga ung OEM foglamps pero mas trip ko ata ung foglamps na malapit sa gitna instead of the OEMs nakakita kasi ako ganda pag gabi pero ok lang din itsura sa umaga parang nakasabit sa gitna hehe, any suggestions on what fog lamps ang kunin ko ung high powered lang ng onti para maganda ang ilaw....
baka palagyan ko din ng tail light garnish baka palagyan ko bulb nakakita ako ganda....
e2 pla ung nakita ko ok din ung kits, any other suggestions on this? addons?
- Mar 2010
- 1
March 26th, 2010 10:55 AM #17
- Jan 2009
- 16
June 1st, 2010 12:15 AM #18may El Dorado sa 20th Ave. cor Aurora boulevard somewhere between Anonas and Cubao area, eastbound side.
June 15th, 2010 02:05 AM #19
front chin
oem foglamps
sideskirts
rear valence and mirage trunk
www.pauuparts.tk
ayan sir ha
July 10th, 2010 03:39 AM #20
Nice car pauu. orig paint ba yan o repaint? ang kinis, san po kayo nagparepaint at magkano? thanks..
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
