Results 21 to 30 of 35
Tsikot Member Rank 4
- Jun 2006
- 2,605
July 2nd, 2007 08:32 PM #21
- Nov 2006
- 299
July 3rd, 2007 11:24 AM #22yes, at kaya nila nirerekomenda ang number of km at number of months.example,5000 km or 5 months whichever comes, first dahil ang matagal na gamit ng oil ay magbibuild up ng sludge,at ang problema sa di masyadong ginagamit ay ang moisture,kaya alin man duon sa dalawa ang mauna ang sundin mo.
July 3rd, 2007 05:15 PM #23
July 3rd, 2007 11:12 PM #24
July 4th, 2007 04:15 PM #25
whapak sa presyo naman yan! di sa contra ako, but is it really worth-it to use it? flushing is merely zeroing out the old/used oil from the engine. di rin effective yun flushing oil pag di machaga un mekaniko sa paghintay ng pagdrain ng oil. important din gamitan ng air yun engine from the opening para completely magbabaan ang mga langis.
im concerned with oil savers too, para san yun at meron din bang high and low quality savers? thanks
Zombie
- Aug 2006
- 728
July 4th, 2007 07:35 PM #26if you follow oil change interval religiously, you wouldn't need engine flush.
too much flushing = cracked gaskets.
- Aug 2007
- 4
August 21st, 2007 01:42 AM #28Sir yung oil mo mukhang ok pa sya after 22k km. Based sa pic na pinost mo, brownish pa sya. Yung mga black deposits sa engine parts is most likely galing pa dun sa mga dating oil mong nagamit.
August 21st, 2007 09:06 AM #29
- Aug 2003
- 9,720
August 21st, 2007 09:46 AM #30just because oil is dark colored, doesn't mean it's bad already, right? what would be a good way to check if oil isn't usable anymore?
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
