Results 1 to 5 of 5
- May 2009
- 2
October 11th, 2010 02:09 PM #1[SIZE=3]I'm having a clutch problem. there is a noise in my clutch every time i step on it.. i need your advice guys.. is it the Fly Wheel?Clutch?Release Bearing? [/SIZE]
- Jul 2007
- 119
October 11th, 2010 03:59 PM #2clutch release bearing. everytime you step your clutch is there a sound?
October 11th, 2010 04:13 PM #3
how long you had your clutch? last time i had problem with a cluch noise on my old infinity G20 was the pressure plate but i could be wrong cuz thats a different car.
- Oct 2010
- 3
November 8th, 2010 06:13 PM #4I have a fairly new A4 and suffer from clutch judder on initial pull-away after the car has been standing overnight. The problem seems to go away after I have pulled away about twice or have been driving for a couple of miles. My father who has a newish Passat has the same issue. Is this a characteristic of these cars and what could be causing this ?
November 12th, 2010 08:24 PM #5
you have to change the whole clutch that is the only solution , or it will gonna end up in this solution only now or later , so change it today .
Monk-owned R53
