Results 11 to 20 of 26
- Jul 2012
- 10
July 11th, 2012 06:16 PM #12uu nga po..sana nga po hose lng..ano po ba ung pde mgkaroon ng leak aside sa hose?sorry po newbie lng tlga po ako..
July 11th, 2012 06:23 PM #13
July 11th, 2012 06:29 PM #14
1. compressor shaft seal. yung ibang compressors hindi na nare-repair.
2. condenser
3. evaporator. sabi mo nilinis nila, baka binabad sa acid. aluminum lang yun, pag nasobrahan baka nagkaron ng butas.
4. yung mga fittings, lalo na sa evaporator at filter-dryer kasi ginalaw nila yun nung nilinis. siguro naman nagpalit ng filter-dryer nung binaba nila ang evaporator mo. baka nag-leak sa connection ng filter-dryer.
5. meron din mga compressors na may pressure relief valve. pwedeng nag-relief yung prv (kung sobrang init, o hindi umandar ang condenser fan) tapos hindi na siya nag-reset ng maayos. nasusundot naman yun, wag lang sana na-wash out.
- Jul 2012
- 10
July 11th, 2012 06:45 PM #15Thank you mga sir..such a big help...papacheck ko na this weekend..same shop..ill keep you posted guys..hopefully mura lng magastos ko..ang gastos pla mgkaauto..hehehe..thanks again po..and god bless to you all..last question mgkno kya maga2stos ko?figure lng..pra mkpaghanda..hehehe
July 11th, 2012 07:37 PM #16
update lang sir. i have a recurring case pero medyo na solve na. nawawala lamig after 2-3 months of cleaning.. in a span of 2 years. i tried different shops, same pa rin. All shops claimed to have found no leaks. actually, malamig sya pero blower gets very weak due to accumulated dirt. Now, i found this good shop , so far its been 6 months ok pa rin. i really dont know why the evap gets dirty easily.
July 11th, 2012 09:37 PM #17
1. if you keep the a/c vent open instead of recirculate that will clog it up fast. or maybe the vent flap door is leaking air in from the outside.
2. do you drive with the windows open?
3. do you have your car vacuumed regularly? regular vacuuming will help keep dirt in the evaporator to a minimum.
4. what clothes do you wear? how about seat covers? if the fabrics used produces a lot of lint then that will also contribute to dirt in the evaporator.
5. i don't want to say this but it is true, household dust is mostly human skin. naghihilod ka ba? araw-araw?
July 11th, 2012 10:42 PM #18
hehe thanks sir yebo, i dont know whats "naghihilod" (im bisaya), but personal hygiene wise im ok. daily bath, wash etc.. eheh
clothes are ok, mostly pang office (poloshirt/long sleeves), except when i go to some construction site, gets a little dirty.
Seat Cover is stock for Honda Civic Sir 99 (dont know if its a factor), but the fabric is not of the leather type.
Ive minimized driving open windows, smoking in the car, as well as using car-fresheners (they say it sticks to the evap)
i vacuum the car, but not as much versus showroom shiny level cars. At all times, AC is set to re-circulate. im not sure if there is already a mechanical defect / leak for my 12 year old civic EK. But so far so good, 6 months na, AC is still good. Never had a similar problem with our other cars though.
- Jul 2012
- 10
July 13th, 2012 03:33 PM #19Guys, gumastos ako ng 6k..pinalitan ung expansion valve..tska ngpalit ng filter at nilinis na rin..lumamig na sya..sana lng tumagal..check lahat wala nmng leak khit ung evaporator and compressor ok nman..sabi nila expansion valve ang sira...hopefully this will do the trick..
July 13th, 2012 03:55 PM #20
a.c. shop na pinapagawaan ko 3months ang warranty nila.... pag hindi nila napalamig ng maganda money back ang offer nila....
Depende po on when dumating yung LTO registration or ano Registration date sa CR/OR nyo. Mine, I...
1st LTO renewal after 3 yr registration
