Results 11 to 20 of 29
November 5th, 2006 10:11 PM #11after replacing the thermostat, check to see if the water jumps out when you start the car and the rad is full. if it does, then it's time to open up the head.
Ano nga ba ang logic behind this?
November 5th, 2006 10:15 PM #12
Isn't the oil supposed to be golden brown instead of dark? Check its consistency, baka malapot. How is the smell?
November 5th, 2006 10:17 PM #13
Black kasi gabi ko tinignan . Yep, malapot siya. Hindi naman burnt smell. Pero baka palitan ko na din after maresolve what's causing the overheating.
November 5th, 2006 10:23 PM #14
I don't know if the Vitara has an overflow hose for the coolant, check if that is somewhat "wet" or if any trace can be seen. If the coolant went out that way, you probably just have a bad thermostat (I hope!)
November 5th, 2006 10:27 PM #15
The overflow hose is just a few inches long (exiting the reservoir). Then it dumps it to the ground. I'm still hoping it's just a bad thermostat.
November 5th, 2006 11:30 PM #16
A coughing sound usually originates from the expansion tank when a gasket is blown. When you open the radiator cap its more obvious. Gases from the cylinder during compression passes through the head gasket finding its way around the water jacket towards the radiator. When you smell the air coming out of the radiator its like exhaust from the tailpipe.
November 5th, 2006 11:49 PM #17
Also check kung meron oil sa rad and reservoir that's also a sign na headgasket failer.White smoke could also be a valve seals(and it should be check if the engine is warm and not early morning).
November 6th, 2006 09:38 AM #18
Wala pong oil sa radiator and wala ding white smoke at operating temp. Antay ko pa ang update regarding the thermostat.
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 6th, 2006 10:56 AM #19the head gasket seals the combustion chamber from the surrounding water passage which cool the cylinder sleeves. when there is a warp in the gasket, the excess combustion goes out into the water passage and will force the water out once the rad cap is opened.
November 6th, 2006 03:14 PM #20
While the engine is dry, you could do a compression test, but I don't know if that'll help much, as sometimes the warping is only obvious at higher loads or when the engine is hot.
I dont know kung ano ang major contirbutor sa incident nayan. Dahil ba made in china yung ev car o...
Hybrids and EV
