Results 21 to 30 of 35
April 5th, 2009 12:44 AM #21
April 5th, 2009 01:13 AM #22
Drive hard (rev higher)..... Spin the compressor faster.....
7808:spam:
April 15th, 2009 09:09 PM #23
Why not install an insulation similar to residential ceilings, the ones they use just beneath the roof. Has anybody tried this? Ma try nga one of these days, anyway mura lang naman per meter sa home depot.Wil DIY it.
April 15th, 2009 09:46 PM #24
yep, yung hi ace ko, nilagyan ko ng insulator in between the roof and the head liner, problem is, sibrang sikip ng space so nalagay ko yung manipis lang
over all no effect... sobrang init talga ng panahon.
mas nakakatulong pa yung nilagay ko na makapal na insulator sa ilalim ng carpet. di na ganong ramdam yung singaw ng kalsada at ng makina.
pero naisip ko , bili kaya ako ng surplus na tank for the windsheild washers... then tutok yung hose sa condenser, para pag na sa trapik pitik pitik ng tubig sa condenser para para makatulong sa pag lamig... hmmmmm
April 15th, 2009 11:48 PM #25
You saved me time and money,Sir impulzz. By the way, thats a good idea intalling a windshield washer.
April 16th, 2009 12:07 AM #26
April 16th, 2009 12:48 PM #27
ok lang sa hiace kasi nasa ilalim naman yung condenser. kaso pag regular sedan or suv pag buga ng tubig deretso sa engine ang talsik, ang dumi ng engine bay kung sakali.
April 16th, 2009 02:14 PM #28
pwede naman siguro i-regulate yung water that sprays the condenser, tipong mist lang
Tsikot Member Rank 4
- 2,716
April 16th, 2009 08:40 PM #29i used those insulators in my old esi but not for car ceiling, instead i cut them for perfect fit on all windows and windshields (so that it would be dark inside) ... very effective to keep out the heat! matrabaho lang ikabit at tanggalin, anim na piraso eh
i believe this is the best way to keep the heat away without using some powered gadget ... most of the heat enters the car via those glasses, so stopping it right there should work effectively
