Results 21 to 30 of 35
- Dec 2006
- 234
July 5th, 2010 07:59 PM #21na isip ko lang bro (though you didn't mention if you overheat with the A/C on or not)... check mo yung condenser ng aircon baka sobrang init because of high pressure from the compressor... if this happens your radiator's cooling efficiency will be impaired ...
July 5th, 2010 08:18 PM #22
before, it overheated only during high speed and while the ac was on. in one occasion however, i blew my rad's upper tank as i failed to notice that my car's was already in its red zone temp. after i replaced the rad, the same scenario of overheating even with on or off a/c...
July 5th, 2010 09:22 PM #23
Obserbahan mo muna iba talaga pag tirik talaga ang araw lalo na noong nakaraang buwan.
July 6th, 2010 08:32 AM #24
hey guys, i uploaded a new video for your comment. pls take note of the smoke coming from the rad and what happened when i revved in the later part of the video... tnx
http://www.zshare.net/video/7800935501e92778/
btw, nothing is unusual during startup but after reaching normal temp (or probably thermostat open), the smoke and bubbles will appear..
July 7th, 2010 04:03 AM #25
hi bro.
gastos at sakit sa ulo talaga lalo na't concerning overheating issues.
if you're problem really can't be helped and confirmed that it's really HG problem (based on your video), i suggest sir na ikaw na bumili ng mga parts (pls go for orig na) para kahit paano ay makatipid ka then have it serviced in reputable shops like speedyfix. in delicate cases just like yours, it pays to have someone who knows what they're doing, otherwise yung binili mong parts (lalo na kung orig) ay masasayang lang dahil palpak ang pagkagawa.
i've been in the same situation as yours before, isang pikit matang gastusan but i have no other choice, kelangan ko pa rin gamitin yung oto ko eh.
goodluck sir!
- Dec 2006
- 234
July 8th, 2010 08:35 AM #27
wala pa din, dito pa kc sa province yung oto. mahirap i travel manila bka masabugan ako uli rad.
October 24th, 2010 04:37 PM #28
October 24th, 2010 09:12 PM #29
December 17th, 2010 02:01 AM #30
hey guys, just want to update you on how I solved my accord's problem and how much it costs me
guess what, the actual cost of the solution is less than 400 bucks and the culprit? radiator lower hose, .
but here is the catch...
I was really convinced that my problem was an HG issue so I decided to order compression and leakdown testers from US, and other different testers, scanners and tools to maximize the items i can place inside the box, preparatory to my plan of having my car top overhauled.
but since my other cars were not available yesterday, thanks to MMDA color coding, i took the courage to use my accord going to manila after i replaced the hose by a replacement one i bought from fertes months ago. although hesitant at first to drive too fast, i noticed however that nothing was unusual in my temp gauge so I decided to speed it up purposely to check if it will overheat just like before. luckily, it did not.
To cut the story short, i solved my long overdue problem for a measly Php400 but i have now a bunch of testers/scanners and mechanic's tools amounting to a new engine that i have no other option but to pay
the lesson i learned, bubbles and highspeed overheat does not necessarily mean an HG problem or blown CH and, the moral of the story, dont presume the worst unless all the petty things have been checked and done already...
BTW, many thanks speed unlimited, sleepsus for your ideas and suggestions... and regards to all.
phezthie
