Results 1 to 10 of 29
- Jan 2008
- 152
March 31st, 2008 04:30 PM #1my radiator cracked due to a faulty thermostat valve.
tinanggal na lang ng mechanic at hindi na pinalitan.
so far, same pa rin yung normal running temperature ko based on my gauge.
since we live in a tropical country, do i still need replace it?
thanks
March 31st, 2008 04:42 PM #2
Yes. Why, because running without a thermostat means that you are running your engine cold every time you start it much longer than with a thermostat that closes and opens whenever your engine reaches its optimal temperature. In short, your engine would take a longer time to reach its optimal temperature. Better replace it bro, mura lang naman.
- Jan 2008
- 152
March 31st, 2008 05:29 PM #3
March 31st, 2008 05:34 PM #4
Yes, it is required to replace it for economical/ efficiency reasons.
However, whats the connection between the Radiator failure and the thermostat. I guess this is also one of the urban legends which must be busted.
March 31st, 2008 05:36 PM #5
March 31st, 2008 05:48 PM #6
Yup, tama si sir dont, baka barado ang radiator mo. With regards to radiator failure, I dont see any connection relating to the thermostat. Ang scenario kasi kung meron kang thermostat is that closed siya during initial startup, meron nang water sa loob ng water jackets ng engine mo, naturally iinit yung nasa water jackets, which causes the thermostat to open (gurus correct me if im wrong is it 110 degrees celcius?), then circulation of water will happen. Tama ba? Baka lalo ka lang nalito hehehe
March 31st, 2008 05:52 PM #7
mabilis mag-init? check your water pump and the radiator itself.... ilang years na po ba? you have the choice: replace it or have it overhauled then finally replace your thermostat- importante yun....on the part of the mech - madali kasing mag-alis kesa maghanap.
March 31st, 2008 06:06 PM #8
We have a REAALLLLLLLYY long thread about this. Search for "great thermostat debate" title.
- Jan 2008
- 152
April 1st, 2008 04:29 PM #9not sure why the top of the radiator cracked. thought it was due to the closed thermostat. temp gauge went over the red line. kaka-overhaul lang ng radiator a few months ago. tumagas yung hose sa likod ng engine.
now, the top is replaced with a fabricated one after another overhaul. still no thermostat any everything still seems normal.
i'll probably replace the thermostat... just to be sure.
thanks
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 1st, 2008 05:05 PM #10The plastic top cracked bec the plastic is like a fuse for your radiator. Its designed to give incase of overheat to protect your head gasket.
Monk-owned R53
