Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Jun 2014
    Hello fellow tsikoters! Need ur expertise on my idling issue. So far what I did, was to clean the throttle body, idling improves however bumabalik un pgka rough lalo pgnsa minor ako.
    Observation: pgngppalit ako ng spark plugs, gmganda nnmn ang idling ko, khit heavy traffic no problem khit on ang aircon.
    Ano ba sa tingin nyo pde ko pang gawin o ipacheck? Btw, my car is grandis chariot. Thanks guys!!
    Apr 2010
    Have your sensors checked with a trusted mechanic sir. Quickstart in Sucat in known for Mitsubishi concerns.
    Peace out!
    Jun 2014
    Quote Originally Posted by theshepherd View Post
    Peace out!
    boss when u say sensors? may specific parts kb na tinutukoy dito? thanks!
    Aug 2012
    Quote Originally Posted by Zac_espaņol View Post
    I think he meant MAF sensors, IACS (Idle Air Control Sensor), Idle Speed Sensor, O2 sensor, etc..
    Try to diagnose using the following list sir:
    Solving Automotive Idle Problems
    Cheers
    when you say rough idling what do you mean? erratic idling kasi is different from rough idling.
    pag erratic idling, sa mga sensors yan specially sa MAF.
    pag rough idling, baka mahigpit yung aircon belt mo o tumitigas na yung compressor pulley resulting in na hindi magandang idling.
    imho.
    Jun 2014
    Boss ano b un rough at erratic idling.
    Aug 2012
    Erratic - Akyat baba ang RPM sa tachometer or yung menor mo taas baba
    Rough - Isang eksena lang na tunog na parang hirap ang makina
    Correct me if I'm wrong.
    Quote Originally Posted by mongobread View Post
    yep. korek bro.
    Jun 2014
    Parang both ah haha pero un pgbaba at pgtaas kc ng rpm ko hindi gnun kdalas na yipong maya't maya. Mnsan kc khit nka neutral e ramdam un rough idling pero hindi gnun kalakas, ramdam mo lang as an owner na kabisado mo takbo nya.
    Aug 2012
    I think erratic po yun sa inyo..
    Yung rough po kasi hindi ka makaka-experience ng taas baba ng RPM.
    Jun 2014
    Salamat mga sirs! I wil have my sensors check then. Mbuti na kc un may idea bago ako pmntang shop. Para di nla tau naloloko
    Jul 2014
    Throttle actuator si ang throttle body mo
    Tsikot Mobile App
    Sep 2014
    Quote Originally Posted by 1D4LV View Post
    imho.
    good pm po sa inyo newbie po...my car is corolla gli 92...may issue din po pala ako ng erratic idling kasi taas baba po yung rpm ko...about dun sa aircon pinalitan yun belt kasi manipis na...after palitan test drive naghigh pressure po yung sa aircon pinatsek ko po sunog ang relay kasi nde po nagautomatic yung fan...pinalitan then ok na po yung fan...pero napansin ko kapag on ang aircon sobra lakas ng vibration ng engine pero kapag off ang aircon stable ang idling ng engine...mga sir need help po ano po kaya problema ng sasakyan ko ang sakit po sa ulo...please help naman po...
    Jul 2011
    Quote Originally Posted by apoltinoteo View Post
    ok lang magvibrate ang engine, walang kaso dun, as long as hindi excessive na
    hanggang cabin ramdam na ramdam.
    nagiiba ba ng idling pag nageengage yung ac compressor?
    your engine is supposed to idle up a little bit higher to compensate for the load your ac compressors gives to the engine.
    900 - 950rpm usually ang idling pag ac engage.
    Jan 2014
    nararanasan kodin yang gayan, pag patay naman ang erkon para naman nag hihingalo ang makina. alangang mamatay o hindi pero kapag nirebolushon lumalakas naman, pag bukas naman erkon at nag otomatik gayon din ang nangyayari sa kanya, pina tsek ko naman compressor, evapoartor, thermostac ayos naman daw sabi technician ng erkon savi baka daw serbo, ganun ba talaga yun?
    Jun 2014
    Update ko lang kayo guys. Nalinis na pla un IAC ko dahil magkasama ndaw un nun pinalinis ko un servo. Ano kaya pa kaya possible na pde ko ipacheck?
    *apoltinoteo maproblema tlga ang may sskyan sir haha sobrang nfeel ko kayo. Pero kailangan natin e hays.
    Check high tension wires, baka tumatalon na korente.
    Aug 2012
    Quote Originally Posted by [archie] View Post
    Do the corona test or water mist test sa gabi.
    Buy a sprinkler, yung tipong ginagamit sa orchids na pang spray or sa pag plantsa.
    Then sa gabi, madilim.. may mumu este start mo engine at spray mo ng water mist yun high tension wires. Pag may nakita ka sparkies yun na yun.
    Jun 2014
    Hi ppcheck ko nga minsan ang wiring ko. Ano ba specific na pde kong sabihin? Bka kc manghuls2 lang un mkkausap ko na electrician
    Feb 2014
    Pareho po kami ng problem ni TS. Kotse ko po e Honda City 1996. Pahingi naman po ng mga inputs nyo.
Rough idling when aircon is on
