Results 1 to 10 of 10
May 11th, 2013 03:21 PM #1
Need to replace my leaking evaporator. a shop quoted me a malaysian brand "season air" (seasonair.com) for 2.1k and a thai brand "paco" (paco.co.th) for 1.9k. Both are serpentine types. my car is a civic 99 ek sir. anyone with experiences with this evap? appreciate the help
ps : the oem Denso is a bit too pricey for me, and based on some reviews here, aftermarket evaps will do just fine. thanks!
Sent from my cherry mobile omega hd using Tapatalk 2
- Jan 2012
- 97
May 13th, 2013 09:38 AM #2sa season air ka na kung makikita mo sila mas makinis ang alumminum ng season air... pero pareho lang sila depende na yan sa system mo kung maayos pa ang compressor mo and other parts....
May 13th, 2013 09:58 AM #3
thank you sir ;) ok lang ba cooling performance ng season air?
Sent from my H100 using Tapatalk 2
- Aug 2005
- 553
May 25th, 2013 01:28 PM #4It is hard to simply recommend one brand based on where its manufactured.
But if that's all I have to go for I would go with the Thai-made ones.
- 52,700
May 25th, 2013 05:49 PM #5my sentra prefers the laminated over the serpentine model... cooler.. and my talyer says the thai models are gooder. hope this helps.
June 11th, 2013 02:00 PM #6
Always prefer the laminated ones. The serpentine type is not recommended for tropical weather. Although the civic came with serpentine, if there are available laminated coil go for it. more rows, better cooling.
- Aug 2005
- 553
June 21st, 2013 05:46 PM #7The serpentine type is normally used for more compact spaces because it forces the refrigerant through a longer pathway therefore maximizing heat transfer. If a larger condenser space is available, you can use parallel ported tubes to diffuse the gasses with a faster system flow rate.
- Jul 2012
- 62
June 26th, 2013 01:00 PM #8Guys, have you tried Ever cool Radiators? I think it's made in the Philippines. i'm sure nakapagreasearch naman siguro sila what's best for our country since it is made here.
Anyone tried one? Naisip ko kasi medyo nakikita ko sila lately sa mga aftermarket shops at so far good feedback naman. gusto ko lang malaman take niyo dito bago ko papalitan ung sa civic 1997 ng dad ko.
- Aug 2005
- 553
July 6th, 2013 10:54 AM #10
IIRC, the local civics came with serpentine type by Sanden. Whereas the JDM ones came with laminated coil, more rows, better cooling. There was a popular mod before where they get the JDM coil and retrofit it to fit the local civic. The results were night and day.
Now if there are replacement laminated coils available for the EK, then that is definitely better. I mean for a thousand or two difference, the better cooling during hot days is priceless.
