View Poll Results: Regular Aircon Cleaning: To be or not to be? Post a Poll
Voters
29. You may not vote on this poll
  • Yup. I prefer a yearly A/C for my vehicle.
    10 34.48%
  • Nope. Just wait for it until it get busted.
    19 65.52%
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
    Aug 2007
    #21
    Mahal yung 2 to 3 thou na cleaning. Usually general cleaning mga 1000-1200 ang price kasama na karga ng freon.
    Jan 2003
    #22
    ^depends if it includes parts like expansion valve and drier.
    Ideally, its better to replace both parts when the evaporator has been pulled down. the drier acts as a filter for the a/c system. it makes no sense to reuse once it has ended its service life. however the expansion valve can be reused but service life won't be the same as a bnew one.
    Feb 2006
    #23
    i always have the drier and expansion valve replaced each cleaning. kahit sabihin sakin ng mechanic na pwede pa i still insist in replacing it para sigurado na
    Aug 2007
    #24
    usually check it once a year. mekaniko barkada ni erpats and lagi nya kse bilin n icheck ko dw at least once year. nging ugali ko n cguro, sort of preventive maintenance na din
    Aug 2007
    #25
    Scenario: Kung wala ng lamig ang aircon tapos pinacheck sa isang aircon repair shop.
    Paano pag sinabi na "sira ang compressor"
    Paano mo malaalman na nagsasabi ng totoo?
    Nov 2004
    #26
    linis yan siyempre ng evaporator siyempre. parehas lang ng sa room airconditioner, nililinis ang evaporator / condenser.
    i have mine cleaned every january or february, just before the summer months
    Nov 2004
    #27
    Quote Originally Posted by suv View Post
    kinakaghan muna nila ng freon yan at nag-leleak test. check din ng a/c clutch. kapag wala pa ring lamig, dedbol na ang compressor
    #28
    Kung may filter ang A/C matagal dudumi ang evaporator kaya change or clean mo lang yong filter. Kung madumi na ang evaporator hindi na lalamig kaya ito lang ang time na dapat linisin ito. Makakatipid ka pa.
  9. FrankDrebin Guest
    #29
    Quote Originally Posted by recklus View Post
    i have both of my cars' a/c cleaned annually since 1 is very old and the other turning 3 yrs. dati kasi with the old car, when i begin to experience problems with the a/c eh dun lang ako nagpapalinis (in a span of 2-3 yrs), lagi nagkakaleak yung cooling coil so lagi palit (mga 3x na ko nagpalit), so i started the habit of having it cleaned annually, so far so good naman. anyway i'm not sure kung may benefits tong ginagawa ko kasi cleaning costs around 2-3k so i try to budget na lang.
    Sir,
    In 2-3 years na annual cleaning niyo mukhang makakabili na kayo ng brandnew na evaporator.
    #30
    revo namin was cleaned last year lang since we bought it 2001. yun mahinang aircon nagparang bago ang buga. pero, nasira din mga vents nito.
    sentra ko naman, am planning to have it cleaned. dati kasi, i use to open the aircon upto medium. tapos giniginaw na kami dun. ngayon nasa pinaka mataas na, bago lumalamig.
    san po ba ok aside from mang mario? ang layo kasi nya eh. saan kaya sa banawe?
    #31
    Kapapagawa ko lang ng A/c ko sabi nung pinagpagawan ko minsan daw dun pa nasisira yan sa pagpapalinis kaya wait na lang pag medyo bumaba na performance di naman siya ganun ka critical, dapat lang malinis lagi yung cabin para matagal siya dumumi
    #32
    better have the air con clean annually yun sira ang compressor or cooling coil can be pre determined pag check the pressure of your freon yun cooling coil numinipis sa katagalan ng gamit there are instance that ngkataon lang malalaman butas yun coil pag nalinisan but parating na yun dun matter of time lang and if you maintain one particular product kahit di air con mas tumatagal siya even out body needs maitainance
    Feb 2006
    #33
    Sir,
    haha oo nga eh, pero i still have it cleaned annually, this way ma-schedule ko talaga within the month of that annual cleaning kapag free ako. unlike kasi before na iniintay ko lang magkaproblema eh nakakasagabal sa work plus need ko pagtiyagaan yung init until i have a free time to have it fixed. so for me i just want to have that peace of mind hehe
    Aug 2007
    #34
    sinasabay ko na lng kapag may pinaayos ako.
    #35
    FYI
    Aircon of car doesn't need a yearly cleaning ... but if your rich enough if couldn't be that bad
    Aircon cleaning usually cost about 1200 depending on what car and depending on which parts are needed to be replace
    for instance basic car model ... usually cost 400- 450 dryer, 700 - 1200 for the expansion valve ( usually honda cars has higher expansion valve since it is lighter type )
    for freon this ranges from 600 - 650 for single aircon meaning the aircon is in the front
    dual aircon car like fx, revo which has aircon both front and rear costs around 1200 - 1300
    for cleaning dual cars usually more expensive about 2800 php this is for general cleaning ... * gen cleaning is removing all parts or aircon, flushing, cleaning and replacing ofr dryer, o ring the works .... usually costs about 5000+
    for those you want to know how to know when your compressor is broken ... usually check ninyo kung sound ng compressor .. yung iba bearing lang ang sira ... which you can hear it
    meron naman walng lamig ang aircon pero puno yung freon ... this means compressor is nagloloko na
    pag ang car minsan may lamig and minsan walang lamig ... walang pressure yung aircon mo (karamihan crv ang may sakit na ganito) ... palit compressor na ito ... mga 18k yata pero mayaman ka naman eh crv yung car mo diba ;)
    for any more questions
    BANAWE AUTO SUPPLY
    7120115
    regy
