Page 1 of 5 12345 LastLast
Results 1 to 20 of 89
    Feb 2017
    Hi po ilan po ba ang row ng radiator ng crv gen 2 manual, at ano po ba maganda replacement na brand?
    at mas maganda ba kung 2 row ang ipapalit kung sakali, parehobba ang size ng 1row at 2row?
    Quote Originally Posted by Gspeedy View Post
    whats the reason for teplacing the radiator?
    doesn't the owner's manual say?
    what do you have in it now?
    oem is probably the safe choice.
    unless, oem has a bad record...
    Feb 2017
    may 5 inch po kasi na crack between the plastic top and metal fins.
    epoxy steel may not hold in long drives.
    Feb 2017
    Wala po sa manual and even sa mga ibang honda dealer sa parts section hindi nila alam kung ilang row.
    may isang nagsabi shop na 1 row daw but not sure kung totoo.
    evercool and hydro and adr yung mga nasearch ko na radiator most of them yata made in taiwan.
    11k sa casa eh mga 5 lang yun replacement.
    Feb 2017
    denso currently installed
    kung nasisilip, bilangin po ninyo ang number of rows?
    1 row lang yan.
    Dec 2017
    I was told by an "expert" to replace the radiator of our CR-V 98 with a bigger one. He claimed that it will yield better fuel economy. I asked him why since the radiator is bigger and heavier. He couldn't answer.
    I simply use what is installed. My recommendation is, use the same specification that came with your car.
    if you plan on "upgrading the radiator", measure them well. baka hindi kumasya yung nais mong gamitin.
    May 2009
    Because a bigger radiator will dissipate the heat faster, creating a more efficient way for the engine to operate optimally? Haha, just guessing not actually stating.
    Feb 2017
    sabi po kasi nung shop pareho lang.
    i'd still bring along a metal tape measure and do my measuring.
    i once tried using a replacement evaporator, as it was cheaper by several thousing bucks than the oem. it didn't fit. using an ordinary metal tape measure, it was off by several mm.
    Quote Originally Posted by sparc179 View Post
    we did, once, in our old besta. it worked fine, naman. but i couldn't tell the difference between a brand new, un-clogged, un-rusted standard-for-model radiator, and a brand new, higher capacity radiator. i did feel more assured, because my new radiator was higher capacity.
    don't worry about "overcooling" (if such exists at all). the thermostat will take care of that.
    May 2011
    Only the additional weight if it matters. The thermostat controls the target temperature and ghe coolant temperature will adjust the operating parametres.
    As long as it fits the bracket.
    Diba meron na mga replacement na Taiwan made? Pwede na yun or tanong ka mismo sa denso baka mura na lang yan.
    Dec 2017
    That somehow makes sense...
    Going back, I was told by another radiator guy to remove the thermostat as it isn't doing any good. I simply smiled.
    So my other recommendation, do not modify the car unless you really know what you are doing.
    "there are times, when one thought one knew what one was doing, when in actuality, one didn't know. removing the thermostat is one such.."
    sometimes, one gets bad advice from a perceived expert in the field.
    Jul 2013
    We used to do that in all our Taxis (after the radiator was replaced by a "replacement")
    Using a Non-factory spec radiator (normally made of copper) has only 2 pros, it's easier to repair AND during those hot summer days, spraying the radiator with water can help the A/C.
    But based on experience with replacement radiators.
    It's bigger - but the rows are actually smaller
    It gets hotter, higher chances of the hood fading quicker
    I would also recommend to remove the thermostat as I'm not sure how will local radiators hold up.
    Only issues I noticed with removing the thermostat is that (1) it will take longer for the car to warm up, if you're driving short distances, it can be really annoying.
    (2) when driving at high speeds out of town, the engine temp will be lower than usual, hence again not reaching the optimum temp of the engine.
    May 2009
    In most of Da Pilipins, over-cooling an engine will never occur. Not even in the highlands, I would think.
    To the TS, also please remember the fan/radiator shrouds which are integral to the design to maximize the airflow into the radiator. Baka po kasi tanggalin at hindi na ibalik.
Radiator replacement
