Results 11 to 20 of 21
- 10,620
October 26th, 2002 09:48 AM #11all are correct!
tip.
kung made of hard plastic ang top and bottom ng radiator mo, pa tanso mo na rin kung papa overhaul mo tutal naka kalas na eh
tip.
always bring water, kahit lagay mo sa 2 liter coke container
tip.
isip pa ako.. later
- 370
October 26th, 2002 10:34 AM #12Pressurized ang cooling system ng engine.
10 mins is more than enough to get the engine to it's normal operating temp.
If you lose water over a short period of time, you may have leaks but it may also mean that you have air pockets lang in your cooling system.
You shouldnt replenish your radiator thru the cap only thru the overflow tank unless you've just changed coolant/water.
The system will draw in the water from the overflow tank when the engien cools down if everything is working as it should.
- 152
- 38
October 28th, 2002 09:07 AM #14Cool gal,
Based dun sa 1st message mo, naturally mababawasan talaga tubig ng radiator kasi pinasirit mo eh. jok lang
but seriously the temperature between C and H is normal considering you have already started it 10 mins already. matagal na yon sakin 5 mins. lang nasa gitna na.
Question, gaano kabilis maubos yung tubig sa radiator mo? marami kasing reason.
- 152
October 28th, 2002 10:32 AM #15di naman nauubos. nababawas lang like isang bote ng maliit na mineral water... :lol: :lol: :lol: mahirap na baka mag overheat pa ko sa daan kaya refill lagi. cautious lang. ang question ko e kung normal ba na sumisirit ang tubig kahit 10mins pa lang bukas makina... :roll:
- 22
October 28th, 2002 10:56 AM #16normal lang ba na after 10 to 15 minutes nakabukas ang makina, when you try to open your radiator e tumatalsik ang tubig at radiator cap at mainit ang tubig? everyday tuloy nilalagyan ko ng tubig radiator para maiwasan mag overheat.
and also after 15mins yung temp ko rises sa middle ng C and H. ok lang ba to? what could be the problem?
- 152
October 28th, 2002 12:01 PM #17di sya fixed between c and h. it rises in the middle of c and h after 10mins. what i need to know is if its normal.
October 28th, 2002 12:47 PM #18
tama yung sinabi ni autoxer, kung may reservoir tank ang kotse mo.. dun ka dapat nagfifill.. kung wala.. no choice but dun sa radiator cap.. just like our cars...
- 38
October 28th, 2002 01:14 PM #19Cool gal, you can have it checked sa certified mechanics, dun ka na pumunta sa mga reputable shops.
I have the same case like that, dinala ko sa servitek. They check the entire cooling system from reservoir, to the hoses, radiators, water pump, and gaskets. they found the cause of the leak is in the gasket. so nilagyan lang ng sealant and walah solve yung problema.
kung kelangan mo yung silicone sealant pahiramin kita, dami pa kasi sobra eh
- 152
Monk-owned R53
