Results 41 to 50 of 127
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 5th, 2007 12:13 AM #41for the most part, water loss can be attibuted to the waterpump only if the pump is leaking. kung walang leak galing dun then your pump should be ok since it is a machanical device lang naman na sabay umikot sa belt/chain ng kotse.
April 6th, 2007 01:12 AM #42
guys tanong ko na din since related din naman sa radiator, coolant expires in 2 yrs, right? ano yun, 2 yrs from the day you open the container and use it in your radiator or 2 yrs from the day of production? naisip ko lang din na sympre may mga old stock na nabibili from shops
- Nov 2003
- 3,849
April 11th, 2007 01:33 PM #43does it expire ba? never noticed a best by date sa mga coolants namin...
April 12th, 2007 02:08 AM #44
ay sorry, wrong term. siguro i'm referring to its life span. may nabasa kasi ako dati thread dito about dexcool coolant ata yun, pwede daw 5 yrs w/o replacing unlike ordinary coolant na 2 yrs.
- Feb 2007
- 5
April 12th, 2007 10:05 AM #45Sa 50/50 mixture ng coolant at tubig, maganda daw panghalo sa coolant ay distilled water. Puwede bang ihalo yung distilled water na panghalo sa Battery at yung Wilkins na pang-inom?
April 12th, 2007 11:55 AM #46
Well, you can put Wilkins in your car... distilled water is distilled water. But the packaging of Distilled Water for batteries isn't food-grade hygenic.
April 12th, 2007 03:31 PM #47
Sa akin naman nababawasan yung tubig sa radiator pero doon sa reservior puno naman. ano kaya ang problema.. using only Distilled water!
- Jun 2005
- 153
April 12th, 2007 09:11 PM #48ganon din sa akin, nababawasan ako ng tubig pero puno ang reservoir, pero di ako nag ooverheat.
April 12th, 2007 10:19 PM #49
We used to lose water in the radiator after 30 or so km's before on our lancer.
That's with a new evercool radiator and radiator cap(0.9)
Then one day, the water loss on the radiator increased and would tend to overheat the engine within 10km's.
I noticed some water stains on the upper hose of the radiator. I found out the clamp on the upper hose isnt holding that much, that is where vapor and water is coming out when the system is on high pressure.
Replaced the clamp and tightened everything. Worked like a charm.
So guys, before spending much on pumps and radiator, check your clamps, hose and fittings for leaks. Or better yet, replace every hose in the cooling system if you suspect and leaks.
**Water level in the reservoir is reduced when we had a defective rad-cap
water level in the radiator decreased when we had a faulty upper hose clamp.(upper hose yung daanan ng tubig na galing sa engine afaik)
April 12th, 2007 11:05 PM #50
No. Do not use the water for battery that you see na for sale sa battery shop for your radiator. Kahit water lang yun may halo pa rin acid though hindi ganun katapang. Found out once when I need to wash my hands and all that is available is the "distilled" water that I bought from a battery shop.
Teka OT na tayo, anu ba yun topic? :P
Daming issue ng SU7:grin:
Xiaomi E-Car
