Results 11 to 20 of 20
November 11th, 2008 09:03 PM #11
^^^ Yung mga shop sa tabi-tabi, simple lang ang pressure testing na ginagawa:
- Tanggalin ang radiator sa kotse, at ibuhos ang tubig/coolant
- Tanggalin ang mga hose na nakakabit
- Pasakan ng bara ang butas sa ilalim ng radiator at ilagay ang radiator cap
- Sa butas sa taas (upper hose), bugahan ng hangin gamit ang bibig. Kapain ang
radiator kung may hangin na sumisirit
Hehehe...
Pero yung mga decent auto repair shops, talagang may mga aparato para matignan kung may butas nga. Same principle lang din gaya ng nasa taas.
THE AUTO SPECIALIST
- Mar 2006
- 607
November 12th, 2008 11:38 AM #12
November 12th, 2008 12:12 PM #14
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 16th, 2008 02:01 PM #15if it'sworn out an ayaw mo sakit ng ulo then just replace the radiator.
December 5th, 2008 03:01 PM #16
December 5th, 2008 03:38 PM #17
December 5th, 2008 05:13 PM #18
many thanks for the info. Last na overhaul ko about 2 months ago was around Php600 lang pero they told me na sasakit talaga ulo ko sa rad ko kasi plastic ung top nya, dapat ung bakal ang gamitin. I'm assuming the Rad prices above are for brand new? i doubt na gagastusan ko ung car ko ng brand new na rad, i'll probably try a surplus kind.
December 5th, 2008 06:40 PM #19
^^^ it's up to you, sa surplus (more than P1,000) kasi walang ka-siguraduhan at tsambahan. matagal nakatambak ang mga yun at sigurado puno na rin ng kalawang. sa bago, taon naman ang bibilangin bukod sa warranty. good luck
December 29th, 2008 09:21 PM #20
update ko lang..finally after kong madala yung auto sa radiator shop..meron palang leak sa bandang baba nung radiator..suggest nila palitan na lang daw ng metal since plastic yung ibabaw nya..so nagfabricate sila nung bottom part ginaya nila yung plastic..yung mounting nung fans pati drain plug etc..
nagtataka lang ako bakit plastic part yung bottom nung rad while yung taas metal..btw accord 96 po yung auto acquired 3 years ago..1.6k charge nila..sana nga tumatal..pero kanina tinignan ko may tumutulo parin pero hindi naman bawas yung radiator at reservoir..ibalik ko na lang bukas sa shop..
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
