Results 1 to 10 of 10
May 8th, 2009 02:57 PM #1
tanong lang po..yesterday while driving (aircon off) pansin ko umaakyat yung temp ko..found out na wala na plang tubig so tinabi ko pinalamig den nag refill ako ng tubig..pansin ko hindi umaandar yung radiator fan ko pero pag naka on ang aircon umaandar naman yung dalawa..pag off aircon di umaandar yung fan..
kaninang umaga inistart ko naghintay ako ng 30 minutes ayaw pa rin mag on nung radiator fan..possible bang busted thermostat ko?
- May 2006
- 913
May 8th, 2009 04:13 PM #2sir somewhere sa wiring system mo there is a sensor that is not working or mai cra na relay.. my best advice is to go to a competent wiring technician and have the radiator fan totally wired separately to the aircon system..
May 8th, 2009 05:35 PM #4
The radiator fan should be the least of your concerns. Dapat pa-check mo muna kung saan yung leak sa cooling system mo, kasi nabawasan ka ng tubig.
May 12th, 2009 12:50 AM #5
update: matagal lang pala mag on yung fan ng radiator..thanks for hte rrply
- May 2006
- 913
May 12th, 2009 08:48 PM #6
- Aug 2006
- 21
May 23rd, 2009 10:30 PM #7
May 24th, 2009 12:11 AM #8
June 4th, 2009 03:15 AM #9
where to buy thermo swtich? seems like mechanics here in fairview area doesnt know what a thermoswitch is
June 4th, 2009 08:53 AM #10
yup, yung thermostat malamang ang problema bro. pero para mas sigurado, consult your mechanic or AC specialist. sayang kasi pag buy ka agad ng parts.
