Results 21 to 24 of 24
- Nov 2005
- 5
November 30th, 2005 05:34 PM #21pag brand new ang sasakyan mo, lagyan mo ng coolant proteksyon kasi yan sa kalawang at rust remover pa. pag luma na yung radiator mo, posibling tumagas pag linagyan mo ng coolant kc manunuot yan sa mga corroded portion ng radiator, pag tagusan na yung corrosion cgurado tagas ang coolant mo. yung kotse ko seven years na hindi pa ako nag paayos ng radiator, walang halong tubig yung coolant ko, puro sya.
December 1st, 2005 09:58 AM #22
if your radiator is denso, go to coolmate pasong tamo. look for boy santos. nangyari na sa akin yan.
December 30th, 2005 08:17 AM #23
Originally Posted by oknamlarry
they have A LOT of radiators on display so you won't miss them.
2K ang charge for parts and labor. ok naman cause mukhang kabisado na nila pagpapalit (took less than an hour to finish the job), and eksakto yung replacement, pati yung holes and alignment, dun sa body ng radiator.
actually saw nearby delta motors pick up a bunch of radiators they had repaired at dante's, apparently sa kanila rin nagpapagawa karamihan ng mga casa.
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 30th, 2005 09:07 AM #24use coolant in a 50-50 mixture.
denso tops normally range between 1500 and 2k+.
cheaper than a complete radiator but normally the whole radiator is better (plus you can sometimes upsize it pa)
Sobrang layo ng comfort ng CX9 vs Fortuner and Everest.
2018 cx-9
