Results 1 to 10 of 27
- Mar 2007
- 26
May 28th, 2009 10:49 AM #1guys panu malaman kung puno ang freon?anu dapat makikita sa sight glass?i just had my aircon fixed and freon refilled.d ako sure kung puno cia.sabi nla dapat clear makikita sa sight glass.hindi clear ang nakikita ko.fluid cia n may pagkawhite.pag ganun naman daw konti lng daw laman.nu b talaga.
May 28th, 2009 11:47 AM #2
dapat clear and walang bubbles...parang ganyan sinasabi dati ng mga gumagawa sa A/C ng cars ko, matagal tagal na rin kasi akong hinde nagpapagawa ng A/C
May 28th, 2009 12:17 PM #3
TS, bawal ang text typing. naka computer ka, di ka naka cellphone.
naintndhn mb?
May 28th, 2009 12:34 PM #4
May 28th, 2009 12:41 PM #5
- Mar 2007
- 26
May 28th, 2009 11:26 PM #6anu ibig sabihin pag umuusok sa vent?sabi hindi daw dapat puno ang freon kasi mahirapan daw ang compressor at baka sumabog daw mga hose pag overcharge.tingin nyo?
- Aug 2008
- 65
May 29th, 2009 03:38 PM #7Dito kasi sa atin dalawa ginagamit na refrigerant - R12 at R134a. Kung [SIZE="4"]R12[/SIZE] pa ang freon ng iyong sasakyan isang indication yung clear glass na ok na ang karga ng aircon.
Ang problema nasa [SIZE="4"]R134a[/SIZE], if you tried to clear the glass puwedeng ma-overcharge ang system. Kung walang proper equipment at data it needs a lot of experience to do it right.
Pag-ganito ang sinasabi sa 'yo ng technician mo, tumakbo ka na lang ng mabilis palayo sa kanya. Hanap ka na lang ng ibang shop.
May 29th, 2009 04:08 PM #8
May 29th, 2009 07:55 PM #9
dcarlo,
although some third world countries still use R12 dichlorodifluromethane(freon r), the earth friendly refrigerant replacement is R134a. if you still have the sight glass on your system, do not use it as a basis for checking if you have the right amount of charge. the sight glass checks are long gone. if your airconditioning system or climate control only uses sight glass if it were an expansion valve type and that it uses freon r. if it uses R143a, the sightglass is no longer built into the receiver/drier. if your system is of the orifice type, i will not have a sight glass. your technical expert should have the table for refrigerant charge for different cars converted to R143a system and that he must know the pressure specs and must know the pressure/temperature chart. otherwise he is guessing. you might be paying him to be a manghuhula and not as a climate control technician.
jick
certified auto
guam
Tsikot Member Rank 4
- 2,716
May 29th, 2009 08:32 PM #10rough guide yung sight glass ... kapag steady yung bubbles (fine bubbles make whitish appearance), kulang lang ng kaunti yung freon, dagdag lang ng kaunti, mawawala na yung bubbles, magiging clear na
karamihan sa mga aircon shops hindi gumagamit ng chart ... wala pa nga ako nakitang gumamit ng chart eh ... titignan lang yung pressure gauges nila, kapag umabot na sa typical value, yun na yun ... hindi na rin tumitingin sa sight glass ... sabay buhusan ng tubig yung condenser, natural lalong lalamig yun, tuwa naman ang customer
