Results 1 to 12 of 12
    My Starex airconditioning system went kaput.
    Compressor shaft seal(?) is the culprit according to the technician.
    According to the store proprietor, there is now a proliferation of "fake freon" that would exactly result to this type of malfunction.
    Is this true?
    Fake freon? or the wrong type of freon was used?
    Example, if your AC unit requires R113, the mechanic used (cheaper) R11 instead.
    Oct 2011
    I think it is the latter sir gh.
    Jan 2008
    yung mga china made yata.. compressor shaft seal naman ang problem eh baka talagang pasira na yung part
    Jan 2011
    ^^ yung nga yung sinasabi nilang fake china made pero hindi naman maging cause para ma damage yung shaft seal
    mas matibay pa raw ung mga surplus na compressor specially denso galing japan
    Aug 2010
    ang sumisira sa shaft seal ay sa tagal narin ng paggamit sa sasakyan normally mga 5years lifespan. shaft seal can hold pressure up to 250PSI, normal freon natin na pang auto r-12 and r-134a ay 100-120psi lang.
    fake freon, maraming brand ng freon malimit sa kanila china namely SOLFRON, DAIKIN, KLEA, GENETRON marami pang ibang brand, sa planta ng sasakyan ganyan din nakikita kong gamit nila, hindi naman porke china pangit na..
    So what is the "best" brand of freon?
    Oct 2011
    Quote Originally Posted by Gerbo View Post
    I'm not famliar with freon brand. Ang importante tama ang refrigerant e.g. R134.
    Given na yan, pre.
    What I was pointing is the presence of some "impurities" or whatever in some vendors of freon that may have detrimental effect on the compressor particularly the shaft seal. As you all know, such defects (i.e leaking shaft seal) warrants a replacement of the entire compressor which is high ticket item.
    The technician i asked asserted that rebuilding the shaft seal won't last long and results in recurring problems.
    Now, I'm asking if there are sellers of "substandard" freonand if this could lead particularly to this problem (the shaft seal defect).
    Jun 2006
    di fake tawag dun,, may halo. . . 134 classification pero may halong r22. result is masisira ang compressor mo. pagbumubili ako ng freon tanong dakin. puro o halo?
    Aug 2010
    650pesos lang ang 134a/kilo kahit anong brand 1kilo ay sobra pa sa isang kotse lalo na pag bago ang compressor.
    r-22 200pesos lang per/kilo wag na haluan pa lalong lalaki ang gastos masisira ang compressor, r-22 gamit yan sa air-con ng bahay. ang mahal lang talaga ay yun talent fee ng gagawa and patong nila sa parts and maraming manloloko.
    actually walang fekeng refrigerant(Freon) maraming klase kanya kanyang chemical content kanya kanyang application, for example R-12 (Diclorodifluoromethane) gamit sa lumang sasakyan/refrigerator
    R-134a (Tetrafluoroethane) gamit sa modelong sasakyan/refrigerator
    R- 22 (Chorodifuoromethane) gamit sa lumang air-con ng bahay
    R- 410a gamit sa modelong air-con ng bahay, paki search nalang ng chemical name.. and marami pang ibang klase.
    ang quality ng lamig sa auto depende na yan sa system mo pag lokal ang evap and medyo luma na and my leak pa mahina rin yan, pag okey lahat parts mo kahit r-12 ilagay mo diyan lalamig yan, wala na yatang nabibiling r-12 ngayon ang ideal na freon yun nasa disposable tank kasi walang corrosion ang tangke, di tulad ng malalaki na refillable.
    sana makatulong serbisyong totoo lang...... merry christmas...
Fake Freon
