Results 1 to 11 of 11
    Hi! I was wondering if i could get some advice,..
    Recenetly kasi, parang nawala na ng lamig yung aircon ng auto ko.. I drive a chery qq 1.1L ..
    Pag mainit ang panahion, ang tagal lumamig, at pag gabi naman eh hindi na siya maginaw, parang a little cooler than normal temp na lang..
    So i decided to bring it sa AC shop, and they discovered that ok naman ung freon level ng compressor, but then hindi umaandar/umiikot ung auxillary fan ko sa harap... Ang ginawa ng mechanic, parang sinundot lang niya ng screwdriver ung fan, then umikot na siya...
    Sabi nila sa akin sira na daw ung aux fan ko and dapat bumili na raw ako ng bago, at nasa 3k siya which I think cost a lot.. So tumawag ako sa casa and they said it would be P2,700...
    But the hting is, gumagana na ngaun ung aux fan ko mula nung sinundot nung mekaniko ng screwdriver, I tried stopping several times, turning off and on my AC, to see if iikot ung aux fan, and it seems ok.,.
    Question is, do I still have to buy a new auxillary fan? Or mas ok ba if pumunta na lang ako ng evangelista para humanap ng surplus?? Kasi for me, the fact na umaandar naman ung fan eh baka may problema lang sa contact, and pwede ko naman i-spray ng WD40 or any contact cleaner.. I was also wondering baka naman malapit na masira yung motor ng fan, di ko naman alam if naipapagawa pa un o ano... 2yrs 7months na yung car..
    I hope you guys can help me with some advice on the best thing that I could do about this..
    Thank You!
    if i were in your situation, observe for a week or so after spraying wd40. kung wala na palya, hindi ko na papalitan. pero kung pumalya kahit isang beses, then palitan na.
    yup! replaced it now...ayaw mo siguro maabutan na masira ang A/C tapos malakas ang ulan. pwede na 2.7k na OEM, pero hanap ka ng replacement mas mura.
    Mura na yung 2700 kung buong assembly na. Yung crv ko dati 8k kaya pinalitan ko motor lang di naman kailangan buong assembly palitan kaya ayun 800 lang nagastos ko sa motor
    Kung may budget e di palitan.... if wala, observe mo na muna ang hanggang gumagana, e di wag palitan.
    Dec 2007
    kung di talaga gumagana ang aux fan need mo talaga to replace it urgently. however need mo din pa check aircon baka nabawasan na
    sya ng freon or compressor oil and need mo na palinis...
    Nov 2007
    tama si boss..mahirap na baka sa daan kapa abutin.
    Mar 2004
    Punta ka sa evangelista, andaming surplusan dyan, marami din na mga kasukat na fan ang pwededen ma-ikabit sa sasakyan mo. Price ranges from 1 to 1.5K depende sa size. Ikaw na mag haggle ng presyo sa kanila. Sama na rin kabit iyan.
    Jul 2011
    pinapalitan ba nyo agad aux fan nga auto nyo? ako kasi poor lang kaya linis terminal at palit brush carbon lang mura pa... unless sira na talaga motor... PEACE
    observe it first then if that happens again then replace it with either a replacement or a surplus kung nagtitipid ka, pwedeng yung motor lang palitan mo para mas mura...ganun lang ginawa ko sa aux fan ko and it is working good, it cost me Php550.00 for the motor, the original price is Php700.00 but i haggle and got it for 550...
    im having "probably" a similar issue.
    What exactly is an aux fan?
    is it the fan for the AC condenser or the radiator? coz in my Civic 99 i got 2 fans (AC and radiator). The prob is i noticed the fan for the radiator isnt working already, although the car hasnt overheated yet. the AC fan still works, but the AC isnt that cool anymore (parang lesser air blowing in).
    Is it possible that due to my busted RAdiator fan, it has affected the AC cooling? or are both fans independent of each other.
    appreciate the help. TIA
Please help me.. :) Aircon problems (auxillary fan)
