Results 1 to 5 of 5
Tsikot Member Rank 4
- Jun 2006
- 2,605
March 28th, 2010 09:58 PM #1How do you find a pin hole leak? I suspect that this is my car's problem as I have been losing about a liter of coolant a month without obvious signs of coolant leaks.
Can you recommend a shop that can do a radiator pressure test?
March 29th, 2010 10:32 AM #2
if this be an external leak and you don't find telltale signs, you can use luminous dye additive to the antifreeze/coolant and look at the possible areas with u.v. light or black light. it will glow like a mother. the antifreeze/coolant had been added this but is in small quantity.
March 29th, 2010 10:56 AM #3
Coolant may be leaking past the head gasket and into the combustion chamber. Do you see white smoke from the exhaust? Then again, the leak had to be a bit more significant for it to show itself through the exhaust.
What car make and model?
What coolant additive do you use? What ratio?
Is the radiator cap pressure valve still within spec?
In reality, we do lose coolant from evaporation. But like you, I also think that 1 liter/month is a bit on the high side.
- Jun 2006
- 2,605
March 29th, 2010 11:06 PM #4
Can you specify the name of the dye and where I can buy it? How much kaya?
I hope its not the head gasket. So far no white smoke, no overheating, no signs of oil in the coolant and vice cersa. Although the car does heat up, during uphill climbs. Turning on the heater cools it dows quickly. From this, I gather that the t-stat, water pump and fans are ok. Radiator was Lavramoned last April 2008, about 20,000 kms ago. So the radiator should still be clean.
Car is a 2002 Chevy Venture. 100,600 kms.
Coolant is 50/50 petron green coolant and distilled water.
Replaced the radiator cap last April 2007, milage then was 70,090 kms.
Just remembered that during the Lavramon, the technician said that the radiator drain plug looks worn. Have to check it.
April 3rd, 2010 05:19 PM #5
