Results 41 to 50 of 60
- 52,701
October 3rd, 2016 11:52 PM #41your engine won't die prematurely, if that is what you are worried about.
a thermostat prevents coolant inside the engine block, from circulating into the radiator.
as a result, your engine gets up to its optimal working temperature, faster.
while that engine is cool, the computer gives it more fuel, sort of "choked".
as a result, engines running cooler than their optimal working temperature, consume more fuel.
bottomline, a working thermostat helps you save on fuel, and lessens pollution.
- Sep 2016
- 14
October 4th, 2016 04:20 AM #42
- Jul 2016
- 1,178
October 4th, 2016 09:00 AM #43Baka radiator cap lang yan sir
Sent from my SM-J500G using Tsikot Forums mobile app
- Sep 2016
- 14
October 5th, 2016 01:23 AM #44
- Sep 2016
- 72
October 5th, 2016 12:01 PM #45ung sakin palaging ubos coolant ung reservoir. kaya di ko na linalagyan ngayon. pero di naman nababawasan dun sa radiator. sa reservoir lang nagbabawas.kapapalit ko lang head gasket.
October 5th, 2016 12:23 PM #46
- Jul 2016
- 1,178
October 5th, 2016 01:56 PM #47Yung orig kunin mo rad cap sir.
- Sep 2016
- 14
October 5th, 2016 09:09 PM #48ok nman sir yung rad cap, japan made din same sukat para sa radiator. pero try ko din bumili sa Toyota.
Update sir sa compression test sa speedyfix. readings - 160-150-150-175.. ok nman daw ganun na reading. wala leaks. hindi rin nila masabi kung ano problema base dun sa compression test. ano pa kaya kelangan test para ma-pin point ang cause ng overflowing coolant sa reservoir at dry ang radiator.
talked to the owner of speedyfix and he suggest na complete overhaul talaga kse dun malaman kung meron crack ang head, warped and cylinder or just simple palit lang ng gasket at oil seals. pero not a guarantee na yun nga ang culprit. big amount of money rin kaya hindi ako maka-decide kung ipa-overhaul ko.
October 5th, 2016 09:43 PM #49
OEM thermostat ba ang ipinalit mo sir?
a faulty rad cap could be the culprit. kahit bago pero kung wala naman sa specs,,,wala din imo.
though i think not necessarily complete overhaul agad iyan. pero kailangan nang mabuksan ang cylinder head then see kung warped whatsoever then start there.
extreme overheat kasi iyan kaya most likely may tama iyan sa loob.
- Apr 2009
- 429
October 7th, 2016 08:31 PM #50Is your new radiator the OEM or a replacement brand? It could also be that your water pump is leaking but not overt and leak dries up immediately with the warm engine. You mentioned the first time that your car overheated and it died along the way. this is not a good sign and could probably mean a warped or cracked cylinder head. check your dipstick if your engine oil is "milky" in character. Oh, in most toyota vehicles that i've seen and owned, i never saw a radiator cap with a 1.1 rating...
